[petsc-dev] Improving nightly builds for maint
Satish Balay
balay at mcs.anl.gov
Wed Oct 18 15:26:55 CDT 2017
On Wed, 18 Oct 2017, Lisandro Dalcin wrote:
> > Alternate is to remove/increase the timout. It doesn't work for some
> > builds anyway [esp valgrind runs]
> > This feature relies on sending 'kill' message to the process it
> > started - i.e mpiexec. But some mpiexecs when killed - don't kill the
> > child processes cleanly]
> > $ git diff |cat
> > diff --git a/bin/maint/buildtest b/bin/maint/buildtest
> > index 31b5a3a028..e4bbf96db8 100755
> > --- a/bin/maint/buildtest
> > +++ b/bin/maint/buildtest
> > @@ -104,7 +104,7 @@ if ( $? ) then
> > else
> > set VALGRIND=`echo MPIEXEC="${PETSC_DIR}/bin/petscmpiexec -valgrind"`
> > setenv PETSCVALGRIND_OPTIONS "--suppressions=${PETSC_DIR}/bin/maint/petsc-val.supp"
> > - set TIMEOUT=720
> > + set TIMEOUT=7200
> > endif
> No, please don't! Be green, Satish!
> What's the point of running a 3D problem under valgrind for 2 hours?
BTW: Just so clarify - eventhough you see a 'killed' message -
currently those jobs are running to completion. [however long it takes
under valgrind]
Satish
> I think we should somehow support
> requires: !valgrind
> and add special code in the test harness (maybe using some environment
> var?) to skip running these tests...
