[petsc-dev] Cleanup of dmhooks in snesdestroy (was: Re: Discussion about time-dependent optimization moved from PR)
Lawrence Mitchell wencel at gmail.com
Wed Oct 18 05:06:55 CDT 2017
> On 17 Oct 2017, at 17:40, Lawrence Mitchell <wencel at gmail.com> wrote:
>> On 17 Oct 2017, at 17:35, Jed Brown <jed at jedbrown.org> wrote:
>>> So my initial concern was that if I do:
>>> SNESSetDM(snes, dm);
>>> SNESSolve(snes);
>>> SNESDestroy(&snes);
>>> Then dm still has stale pointers to snes (in the context of the
>>> restrict hook).
>> Thanks, this is fixable.  Can someone make a test case for me?
> I'll try and cook one up tomorrow.
Here we go.
This just reuses a DA in a loop making two SNESes to solve the same problem.
$ ./dmhookcleanup -da_refine 1 -pc_type mg  -snes_fd_color -snes_monitor
  0 SNES Function norm 4.375000000000e-01
  1 SNES Function norm 1.086628858540e-05
  2 SNES Function norm 7.356279464858e-12
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Wrong type of object: Parameter # 2
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.7.6-3851-g17f6384  GIT Date: 2017-05-09 22:45:05 -0500
[0]PETSC ERROR: ./dmhookcleanup on a arch-linux2-c-dbg named yam.doc.ic.ac.uk by lmitche1 Wed Oct 18 11:04:11 2017
[0]PETSC ERROR: Configure options --download-chaco=1 --download-ctetgen=1 --download-exodusii=1 --download-hdf5=1 --download-hypre=1 --download-metis=1 --download-ml=1 --download-mumps=1 --download-netcdf=1 --download-parmetis=1 --download-ptscotch=1 --download-scalapack=1 --download-triangle=1 --download-eigen=1 --with-c2html=0 --with-debugging=1 --with-make-np=32 --with-shared-libraries=1 PETSC_ARCH=arch-linux2-c-dbg
[0]PETSC ERROR: #1 MatRestrict() line 8044 in /data/lmitche1/src/deps/petsc/src/mat/interface/matrix.c
[0]PETSC ERROR: #2 DMRestrictHook_SNESVecSol() line 528 in /data/lmitche1/src/deps/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: #3 DMRestrict() line 2421 in /data/lmitche1/src/deps/petsc/src/dm/interface/dm.c
[0]PETSC ERROR: #4 PCSetUp_MG() line 729 in /data/lmitche1/src/deps/petsc/src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: #5 PCSetUp() line 924 in /data/lmitche1/src/deps/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #6 KSPSetUp() line 378 in /data/lmitche1/src/deps/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #7 KSPSolve() line 609 in /data/lmitche1/src/deps/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #8 SNESSolve_NEWTONLS() line 224 in /data/lmitche1/src/deps/petsc/src/snes/impls/ls/ls.c
[0]PETSC ERROR: #9 SNESSolve() line 4106 in /data/lmitche1/src/deps/petsc/src/snes/interface/snes.c
[0]PETSC ERROR: #10 main() line 61 in /data/lmitche1/src/petsc-doodles/dmhookcleanup.c
[0]PETSC ERROR: PETSc Option Table entries:
[0]PETSC ERROR: -da_refine 1
[0]PETSC ERROR: -pc_type mg
[0]PETSC ERROR: -snes_fd_color
[0]PETSC ERROR: -snes_monitor
[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 62.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
valgrind log:
==2215210== Memcheck, a memory error detector
==2215210== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==2215210== Using Valgrind-3.11.0 and LibVEX; rerun with -h for copyright info
==2215210== Command: ./dmhookcleanup -da_refine 1 -pc_type mg -snes_fd_color -snes_monitor
==2215210== Parent PID: 1523638
==2215210==
==2215210== Warning: noted but unhandled ioctl 0x30000001 with no size/direction hints.
==2215210==    This could cause spurious value errors to appear.
==2215210==    See README_MISSING_SYSCALL_OR_IOCTL for guidance on writing a proper wrapper.
==2215210== Warning: noted but unhandled ioctl 0x27 with no size/direction hints.
==2215210== Warning: noted but unhandled ioctl 0x7ff with no size/direction hints.
==2215210== Warning: noted but unhandled ioctl 0x25 with no size/direction hints.
==2215210== Warning: noted but unhandled ioctl 0x17 with no size/direction hints.
==2215210== Warning: set address range perms: large range [0x1000000000, 0x2100000000) (noaccess)
==2215210== Warning: set address range perms: large range [0x200000000, 0x400000000) (noaccess)
==2215210== Invalid read of size 8
==2215210==    at 0x63E30DD: DMRestrictHook_SNESVecSol (snes.c:519)
==2215210==    by 0x5A3C98B: DMRestrict (dm.c:2421)
==2215210==    by 0x61A3C7A: PCSetUp_MG (mg.c:729)
==2215210==    by 0x61E581C: PCSetUp (precon.c:924)
==2215210==    by 0x6334EB8: KSPSetUp (itfunc.c:378)
==2215210==    by 0x6336C76: KSPSolve (itfunc.c:609)
==2215210==    by 0x6484F80: SNESSolve_NEWTONLS (ls.c:224)
==2215210==    by 0x640A12D: SNESSolve (snes.c:4106)
==2215210==    by 0x4014EA: main (dmhookcleanup.c:61)
==2215210==  Address 0x150a5aa0 is 688 bytes inside a block of size 1,280 free'd
==2215210==    at 0x4C2EDEB: free (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==2215210==    by 0x51565F6: PetscFreeAlign (mal.c:85)
==2215210==    by 0x63FE427: SNESDestroy (snes.c:2896)
==2215210==    by 0x401550: main (dmhookcleanup.c:62)
==2215210==  Block was alloc'd at
==2215210==    at 0x4C2FFC6: memalign (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==2215210==    by 0x515653C: PetscMallocAlign (mal.c:39)
==2215210==    by 0x63EE313: SNESCreate (snes.c:1553)
==2215210==    by 0x4013A7: main (dmhookcleanup.c:58)
==2215210==
==2215210==
==2215210== HEAP SUMMARY:
==2215210==     in use at exit: 908,831 bytes in 9,597 blocks
==2215210==   total heap usage: 52,827 allocs, 43,230 frees, 959,732,566 bytes allocated
==2215210==
==2215210== LEAK SUMMARY:
==2215210==    definitely lost: 674 bytes in 9 blocks
==2215210==    indirectly lost: 649,619 bytes in 9,354 blocks
==2215210==      possibly lost: 2,800 bytes in 21 blocks
==2215210==    still reachable: 255,738 bytes in 213 blocks
==2215210==         suppressed: 0 bytes in 0 blocks
==2215210== Rerun with --leak-check=full to see details of leaked memory
==2215210==
==2215210== For counts of detected and suppressed errors, rerun with: -v
==2215210== ERROR SUMMARY: 2 errors from 1 contexts (suppressed: 0 from 0)
Code:
#include <petsc.h>
static PetscErrorCode FormFunctionLocal(DMDALocalInfo *info, PetscScalar **xarr, PetscScalar **farr, void *ctx)
  PetscInt       i, j;
  PetscReal      hx, hy, hxdhy, hydhx;
  PetscScalar    u, ue, uw, un, us;
  PetscFunctionBeginUser;
  hx     = 2.0/(PetscReal)(info->mx-1);
  hy     = 2.0/(PetscReal)(info->my-1);
  hxdhy  = hx/hy;
  hydhx  = hy/hx;
  for (j=info->ys; j<info->ys+info->ym; j++) {
    for (i=info->xs; i<info->xs+info->xm; i++) {
      if (i == 0 || j == 0 || i == info->mx-1 || j == info->my-1) {
        farr[j][i] = 2.0*(hydhx + hxdhy)*xarr[j][i];
      } else {
        u  = xarr[j][i];
        uw = xarr[j][i-1];
        ue = xarr[j][i+1];
        un = xarr[j-1][i];
        us = xarr[j+1][i];
        if (i-1 == 0) uw = 0.;
        if (i+1 == info->mx-1) ue = 0.;
        if (j-1 == 0) un = 0.;
        if (j+1 == info->my-1) us = 0.;
        farr[j][i] = (2.0*u - uw - ue)*hydhx + (2.0*u - un - us)*hxdhy - hx*hy;
  PetscFunctionReturn(0);
int main(int argc,char **argv)
  SNES           snes;
  PetscErrorCode ierr;
  DM             da;
  PetscInt       i;
  ierr = PetscInitialize(&argc,&argv,NULL,NULL);
  if (ierr) return ierr;
  ierr = DMDACreate2d(PETSC_COMM_WORLD, DM_BOUNDARY_NONE, DM_BOUNDARY_NONE,
                      DMDA_STENCIL_STAR, 5, 5, PETSC_DECIDE, PETSC_DECIDE,
                      1, 1, 0, 0, &da);CHKERRQ(ierr);
  ierr = DMSetFromOptions(da);CHKERRQ(ierr);
  ierr = DMSetUp(da);CHKERRQ(ierr);
  ierr = DMDASNESSetFunctionLocal(da, INSERT_VALUES, (PetscErrorCode (*)(DMDALocalInfo*,void*,void*,void*))FormFunctionLocal,NULL);CHKERRQ(ierr);
  for (i = 0; i < 2; i++) {
    ierr = SNESCreate(PETSC_COMM_WORLD,&snes);CHKERRQ(ierr);
    ierr = SNESSetDM(snes,da);CHKERRQ(ierr);
    ierr = SNESSetFromOptions(snes);CHKERRQ(ierr);
    ierr = SNESSolve(snes,NULL,NULL);CHKERRQ(ierr);
    ierr = SNESDestroy(&snes);CHKERRQ(ierr);
  ierr = DMDestroy(&da);CHKERRQ(ierr);
  ierr = PetscFinalize();
  return ierr;
Cheers,
Lawrence
