[petsc-dev] Threadsafe for Matrix assemby in Petsc?
Mark Adams
mfadams at lbl.gov
Tue Oct 17 15:07:11 CDT 2017
There is no support for threaded matrix assembly in PETSc. Here is a recent
email thread on the issue:
https://mail.google.com/mail/u/0/#search/label%3Apetsc+thread+assembly/15f10d078e9ea8e7
So you pretty much have to deal with race conditions yourself. There are
several failure modes with threads:
1) Off processor entries are stashed in a global data structure for a
scatter/gather stage during matrix finalize. A simple fix for this is to
have every processor compute all elements that touch its vertices
(overlapping element decomposition) and then have PETSc ignore off
processor entries. This is how I do it to simply avoid communication with
redundant computation. It also avoid synchronization.
2) The 1D array data structure is reconstructed when the data spills the
preallocated memory. Solution: allocate memory exactly.
3) Just normal race conditions. Coloring is the basic approach to this
problem, although I think Jed thinks this is not sufficient in PETSc as is.
4) unknown unknowns.
On Tue, Oct 17, 2017 at 3:24 PM, Yoon, Eisung <yoone at rpi.edu> wrote:
> Hi Mark,
> Seegyoung here in SCOREC is looking for a way to assemble elements for a
> global matrix with PETSC using threads. I’m aware that you have installed
> thread-safe PETSC into NERSC system for XGC and you know details about
> PETSC.
> So could you tell us if PETSC supports thread-safe global matrix assembly
> with thread-safe version of PETSC, and some details, please?
> Seegyoung might describe more details about her problem later.
> Thank you.
> Best,
> ES
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171017/e7f3897d/attachment.html>
