[petsc-dev] Discussion about time-dependent optimization moved from PR
Jed Brown
jed at jedbrown.org
Tue Oct 17 10:00:31 CDT 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
>>>> On Oct 17, 2017, at 7:43 AM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
>>>> What happens if you call TSCreateAdjointsTS() on a TS obtained with TSCreateAdjointsTS()? Is the resulting TS useful?
>>>> I don't think so.
>>> Hmm, this is rather bothersome. So the new TS that comes out is not
>>> really a full-featured TS (using your new extended TS object that
>>> knows about adjoints)?
>> Is it useful to precondition Newton with Newton preconditioned with
>> Newton?
>>> It is like a subclass of TS that can only do timestepping? This
>>> goes back to my concern that TS shouldn't be overloaded with all
>>> the adjoint sensitivity stuff, there should be a higher level
>>> PetscSensi object that does sensitivities and it contains multiple
>>> TS for the ODE/DAE integrator and one for "reverse" mode.
>> Let's not mix together Stefano's TSComputeObjectiveAndGradient (which
>> could easily go into a helper PetscSensi) with the control flow needed
>> to create/integrate an adjoint system.
> Jed,
> I am not mixing them! I am not even considering the TSComputeObjectiveAndGradient() at all I am only considering
> the "the control flow needed to create/integrate an adjoint system." My PetscSensi is not for TSComputeObjectiveAndGradient level stuff.
Okay, interesting.
>> In my opinion, it must be
>> possible to have a comparable/same interface to create a discrete
>> adjoint (which depends on the forward implementation) as to create a
>> continuous adjoint (with customizable space and time discretization).
> Absolutely and fundamentally. No argument at all about this.
>> I think we should postpone discussion of higher level convenience
>> functions like TSComputeObjectiveAndGradient or some new organization
>> thereof until we agree about the basic representation of adjoints.
> Totally agree and that is what I have done.
>> My
>> preference is for TSCreateAdjointTS() which the user can customize to
>> use arbitrary time integration methods (thus becoming a
>> "continuous-in-time" adjoint) and to use different spatial
>> discretizations (for consistency with the adjoint PDE).
> I understand, I think TSCreateAdjointTS() is not the right model. I think that the correct model is, for example
> PetscSensiCreate()
> PetscSensiSetObjective.... or whatever etc etc
> PetscSensiGetIntegrator(,&TS)
> PetscSensiGetAdjointIntegrator(,&TS).
How would PetscSensiGetAdjointIntegrator be implemented? Since it needs
to be able to create a discrete adjoint (which depends on the forward TS
implementation), the control flow *must* go through TS. What does that
interface look like?
> Note I am not married to the current model of TSSolve/TSAdjointSolve().
> Barry
