[petsc-dev] Discussion about time-dependent optimization moved from PR
Jed Brown
jed at jedbrown.org
Tue Oct 17 08:19:33 CDT 2017
Matthew Knepley <knepley at gmail.com> writes:
>> >> It's a recipe for confusion. Either the parameters are never passed
>> >> explicitly or they are always passed explicitly and should not be stored
>> >> redundantly in the context, thus perhaps enabling some sort of higher
>> >> level analysis that dynamically changes parameter values. I would go
>> >> with the former for now.
>> > I want to say again how much I dislike ad hoc memory layouts through
>> > contexts and the like. We have a perfectly good layout descriptor (DM)
>> > that should be used to describe data layout.
>> This is an independent change from the adjoint work and I think it's out
>> of scope right now. If we change it, it should go in its own PR. I
>> don't like having one PR with a smattering of non-essential changes to
>> old interfaces bundled together with new conventions and new
>> functionality.
> My understanding was that this discussion is not about a particular
> PR, but about the interface we should have for sensitivity and optimal
> control.
Sure, but changing the way parameters are passed isn't an essential part
of the adjoint interface. This particular debate spawned from Stefano's
claim that passing the parameter vector to one of his functions was a
feature of his interface relative to Hong's. I replied that it was an
inconsistency -- we should either change all interfaces to pass
parameter vectors explicitly or we never pass them.
But any such change would be orthogonal to the merits of TSAdjointSolve
versus TSCreateAdjointTS. Indeed, discussion of how parameters are
accessed is derailing the present discussion from this crucial
difference in interfaces. Let's cut it out of the current thread.
I want to hear rationale for TSAdjointSolve() or a plan for refactoring
those algorithms into TSCreateAdjointTS().
>> Putting the parameters in a vector would enable finite differencing of
>> the RHSFunction to obtain its dependence on parameters. That might have
>> high (non-scalable in number of parameters) cost, but would be less
>> expensive than finite differencing an entire model. Consider the
>> scenario of 100 parameters and 1e6 state variables (at each time step).
>> If we have the ability to apply the transpose of the Jacobian with
>> respect to model state, we could run an adjoint simulation and only need
>> 100 RHSFunction evaluations per stage, rather than 100 solves.
> I am not sure of the point of the above paragraph. Saying the point rather
> than implying
> the point helps me.
It is a potential functional case for making the parameter vector an
explicit argument.
