[petsc-dev] Discussion about time-dependent optimization moved from PR
Matthew Knepley
knepley at gmail.com
Tue Oct 17 07:28:39 CDT 2017
On Tue, Oct 17, 2017 at 8:16 AM, Jed Brown <jed at jedbrown.org> wrote:
> Stefano Zampini <stefano.zampini at gmail.com> writes:
> >> >> In case of multiple objectives, there may be a performance reason to
> >> >> amortize evaluation of several at once, though the list interface is
> >> >> convenient. Consider common objectives being quantities like lift
> and
> >> >> drag on different surfaces of a fluids simulation or stress/strain at
> >> >> certain critical joints in a structure. Although these have some
> >> >> locality, it's reasonable to assume that state dependence will have
> >> >> quickly become global, thus make no attempt to handle sparse
> >> >> representations of the adjoint vectors lambda.
> >> > I don't get this comment. Is it related with multi-objective
> optimization
> >> > (e.g. Pareto)?
> >> Adjoints are usually preferred any time you are differentiating a small
> >> number of output variables with respect to a large number of inputs. It
> >> could be for multi-objective optimization, but it's every bit as
> >> relevant for physical sensitivities.
> > If we are not talking about Pareto optimization, and thus we don't need a
> > separate output from each function, then users can pass a single function
> > that computes all the quantities they need at the same time. Anyway, I
> > don't mind having a single callback for multiple functions.
> I don't follow why multi-objective optimization would be any different.
> Are you supposing that the different objective functions would be
> implemented by different software packages?
> >> >> How are parameters accessed in TSComputeRHSFunction? It looks like
> >> >> they're coming out of the context. Why should this be different?
> (If
> >> >> parameters need to go into a Vec, we could do that, but it comes at a
> >> >> readability and possibly parallel cost if the global Vec needs to be
> >> >> communicated to local vectors.)
> >> > design paramaters are fixed troughout an adjoint/tlm run. They can be
> >> > communicated locally once at the beginning of the run.
> >> > This is what TSSetUpFromDesign and TSSetSetUpFromDesign are supposed
> to
> >> > handle, if I get your comment.
> >> My point is that users currently get design parameters out of the
> >> context when evaluating their RHSFunction and friends. If that is the
> >> endorsed way to access design variables, then your new function doesn't
> >> need to pass the vector. If you need to pass the parameter vector in
> >> that one function, instead of obtaining them from the context, then
> >> you'd need to pass the parameter vector everywhere and discourage using
> >> the context for active design variables. I think there are merits to
> >> both approaches, but it absolutely needs to be consistent.
> > So, to be consistent, we have to force users to perform an operation in a
> > single way?
> > Yes, TSSetUpFromDesign is among the last things I have added, and allows
> to
> > update the application context (among other things, as it is very
> general).
> > I can remove the parameter vector from TSEvalGradientDAE and
> > TSEvalGradientIC; however, having these vectors there makes it clear that
> > we allow non-linear dependency on the parameters too.
> There are a bunch of other places that allow nonlinear dependence on
> parameters yet don't pass that parameter Vec, including
> TSSetRHSFunction. If it is passed explicitly in one such function, it
> needs to be passed explicitly in all.
> > I can add a comment on the man pages that the vectors are guaranteed
> > to be the same one passed in my TSSetUpFromDesign, or remove
> > them. Your call.
> It's a recipe for confusion. Either the parameters are never passed
> explicitly or they are always passed explicitly and should not be stored
> redundantly in the context, thus perhaps enabling some sort of higher
> level analysis that dynamically changes parameter values. I would go
> with the former for now.
I want to say again how much I dislike ad hoc memory layouts through
contexts
and the like. We have a perfectly good layout descriptor (DM) that should
be used
to describe data layout.
Matt
> > Users can do anything they want with the forward model context, but they
> > are not free to change the application context of the adjoints TS. Maybe
> > this should be improved by adding and extra slot to AdjointTSCtx to carry
> > over the user context (for the adjoint I mean)?
> Why do you need to own the application context for the adjoint TS,
> versus using the context parameters to TSSetRHSJacobian, etc.
> >> > https://bitbucket.org/petsc/petsc/src/c2e9112e7fdfd89985f9ffc4d68b0d
> >> 46cf7cad52/src/ts/interface/tspdeconstrainedutils.c?at=
> >> stefano_zampini%2Ffeature-continuousadjoint&fileviewer=
> file-view-default#
> >> tspdeconstrainedutils.c-579
> >> > Here is how ex23.c uses it
> >> 46cf7cad52/src/ts/examples/tutorials/ex23.c?at=stefano_
> zampini%2Ffeature-
> >> continuousadjoint&fileviewer=file-view-default#ex23.c-677
> >> And yet you redo the scatter here instead of using what you stuffed into
> >> the context. If you needed to redo it for correctness, you'd also need
> >> to in every other function that accesses design parameters.
> zampini%2Ffeature-
> >> continuousadjoint&fileviewer=file-view-default#ex23.c-274
> > This is a leftover from a previous version of the code (there's also a
> > comment) that was not using TSSetSetUpFromDesign and it's definitely not
> > needed.
> Comments that some lines of code can be deleted is a good sign that they
> should be deleted.
> >> >> > Both methods need the Jacobian of the DAE wrt the parameters: H
> >> >> > TSAdjointSetRHSJacobian(), S TSSetGradientDAE()
> >> >> > Initial condition dependence on the parameters is implicitly
> computed
> >> in
> >> >> > Hong's code (limited to linear dependence on all the variables);
> >> >> How so? Once the user gets \lambda(time=0), they can apply the chain
> >> >> rule to produce any dependency on the parameter vector?
> >> >> Yes, the chain rule is implemented here
> file-view-default#
> >> tspdeconstrainedutils.c-254
> >> I know you have a callback for it, but Hong's interface is plenty
> >> functional for such systems, they just call that derivative instead of
> >> writing and registering a function to do that.
> > I'm not saying HOng's interface is not functional.
> I was responding to your statement that "Initial condition dependence on
> the parameters is limited to linear dependence on all the variables" in
> his approach. General dependence is supported, the user is just
> expected to call it themselves rather than registering a callback that
> TS calls.
> > The initial condition gradients allow to automatize the process in
> > TSComputeObjectiveAndGradient(), TSComputeHessian(), and
> > MatMult_Propagator(). Anyway, the lambda variables are not modified by
> > AdjointTSComputeFinalGradient() (that adds the IC dependency) and
> > users can do whatever they want with them.
> > I know you don't like TSComputeObjectiveAndGradient(),
> I don't have a problem with the concept but don't want to rely on it.
> I'd rather discuss how to unify interfaces for discrete and continuous
> adjoints and get a PR for it merged before adding higher level
> interfaces.
> > but it's a code that anyway users have to write to compute a gradient
> > of the DAE not arising from a PDAE. How can this be automatized for
> > PDAEs? Should we store the AdjointTS inside the model TS and use
> > TSGetAdjointTS(ts,&ts->adjts) with
> I see reasons for the adjoint TS to hold a reference to the forward TS,
> but not vice-versa. What is the use case for your proposal below?
> > TSGetAdjointTS(TS f,TS* a) {
> > if (!f->adjtts) TSCreateAdjointsTS(f,&f->adjts);
> > *a = f->adjts:
> > and the corresponding Setter to allow users to do
> > TSCreateAdjointTS(ts,&atts)
> > TSSetRHSJacobian(ats,...)
> > TSSetAdjointTS(ts,ats)
> > or
> > TSGetAdjointTS(ts,&atts)
> > Stefano
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171017/0cc0f398/attachment.html>
