[petsc-dev] PetscSF in Fortran
Adrian Croucher a.croucher at auckland.ac.nz
Sun Oct 15 17:54:11 CDT 2017
hi
On 14/10/17 00:47, Matthew Knepley wrote:
> If you want the wrapper to take in F90 pointer arguments, then you
> have to declare it or you get an SEGV. These
> get autogenerated in include/petsc/finclude/ftn-auto/*.h90 when you
> run 'make allfortranstubs'. Did this happen
> for your function?
I just tried running make allfortranstubs, but I don't see anything new
in include/petsc/finclude/ftn-auto/*.h90, and my test program still crashes.
I also tried doing a make clean and make allfortranstubs all, but that
didn't help.
I even tried deleting my $PETSC_ARCH directory and rebuilding everything
(including make allfortranstubs) but again it didn't help.
I'm a bit surprised that custom Fortran bindings should produce anything
in include/petsc/finclude/ftn-auto/, I thought that would only be for
the auto-generated stuff that comes out of bfort?
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171016/28a8e083/attachment.html>
