[petsc-dev] DMPlex "chart" term
Wed Oct 11 03:58:40 CDT 2017
On Wed, Oct 11, 2017 at 4:54 AM, Patrick Sanan <patrick.sanan at gmail.com>
wrote:
> Another terminology question to help with the docs.
> What's the origin of the term "chart" in DMPlex? I'm only previously
> familiar with the term in the context of manifolds (where chart =
> homeomorphism from an open set in the manifold to an open set in R^n).
That is what it is supposed to be. A chart is coordinates on a patch of the
manifold. We intend the same thing here in that you can
locally refer to points with a given name, but they may have a different
name on another chart (process). The names are matched up using the PetscSF.
> In terms of the use in DMPlex, is there anything wrong with thinking of
> "chart" as a shorter way to say "interval of integers, closed on the left
> and open on the right, e.g.  [pStart,pEnd)"?
No, since we depend on continuity of point names almost everywhere.
  Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171011/87783f8f/attachment.html>
