[petsc-dev] DMLabel in Fortran
    Adrian Croucher
    a.croucher at auckland.ac.nz
    Tue Oct 10 20:07:37 CDT 2017
hi
On 03/08/17 13:10, Matthew Knepley wrote:
> On Wed, Aug 2, 2017 at 8:06 PM, Adrian Croucher
> <a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>> wrote:
>     I haven't tried this myself, but two of my colleagues are
>     reporting problems accessing DMLabel from Fortran, when using the
>     latest 'next' branch.
>     Previously, #include <petsc/finclude/petsc.h> and then 'use petsc'
>     would give access to DMLabel.
>     But now it appears that doesn't work- you need to include
>     petscdmlabel.h as well.
>     Is that a bug or a feature?
> Its a bug. We refactored DMLabel to make all functionality available
> from Fortran, including using it as a type, but
> I did not put the new header inside petsc.h. I can do that.
>    Matt
It appears this never got done, so I have had a look and (I think)
figured out how to fix it myself.
I've just submitted a pull request with the fix in a branch called
acroucher/fix-fortran-dmlabel.
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171011/ab09b6c4/attachment.html>
