[petsc-dev] development version for MATAIJMKL type mat
Mark Adams mfadams at lbl.gov
Tue Oct 10 15:24:21 CDT 2017
So you want to run 16 MPI ranks. That is not bad. I was afraid you want to
use like 1 or 2 MPI processes per socket.
I would not be optimistic that you are going to get a win with OMP here.
But it would be good to get some data. Talk with the hypre folks, they can
debug hypre and they have a lot more experience with OMP + AMG and can give
you a better sense of what to expect.
On Tue, Oct 10, 2017 at 4:06 PM, Bakytzhan Kallemov <bkallemov at lbl.gov>
wrote:
> On 10/10/2017 12:47 PM, Mark Adams wrote:
>    What are you comparing? Are you using say 32 MPI processes and 2
>> threads or 16 MPI processes and 4 threads? How are you controlling the
>> number of OpenMP threads, OpenMP environmental variable? What parts of the
>> time in the code are you comparing? You should just -log_view and compare
>> the times for PCApply and PCSetUp() between say 64 MPI process/1 thread and
>> 32 MPI processes/2 threads and send us the output for those two cases.
> These folks don't use many MPI processes. I'm not sure what the optimal
> configuration is with Chombo-Crunch when using all of Cori.
> Baky: how many MPI processes per socket are you aiming for on Cori-KNL?
> right now I am testing it on a single KNL node going from flat 64+1 to
> 2+32 for comparison.
> But as you can see from the plot in the previous mail, we have a sweet
> spot at 16+4 point, then we scale that accordingly when running
> with 8k nodes.
>> > It seems that it made no difference, so perhaps I am doing something
>> wrong or my build is not configured right.
>> > Do you have any example that makes use of threads when running hybrid
>> and show an advantage?
>>    There is not reason to think that using threads on KNL is faster than
>> just using MPI processes. Despite what the NERSc/LBL web pages may say,
>> just because a website says something doesn't make it true.
>> > I'd like to test it and make sure that my libs are configured
>> correctly, before start to investigate it further.
>> > Thanks,
>> > Baky
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171010/1aacc210/attachment.html>
