[petsc-dev] patch for batched config
Stefano Zampini stefano.zampini at gmail.com
Tue Oct 10 09:01:46 CDT 2017
from
https://www.gnu.org/software/autoconf/manual/autoconf-2.69/html_node/Hosts-and-Cross_002dCompilation.html
Now, configure enters cross-compilation mode if and only if --host is
passed.
So, you just tell configure that the host where you are going to run the
code is different from the building CPU, but you do not specify a string
associated with it, which should be fine
2017-10-10 16:53 GMT+03:00 Matthew Knepley <knepley at gmail.com>:
> On Tue, Oct 10, 2017 at 9:48 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> I never understood --host option of autoconf - and it would rarely
>> work for me.
> I do not understand this option either. Jed, what does it do?
>   Matt
>> For packages where '--with-batch --download-package' did not work -
>> our suggstion so far was to install them manually.
>> I'm hesitant to add this patch [it might work on one setup - but not
>> the other?] - but Matt/Jed might have better suggestions.
>> cc:ing petsc-dev
>> Satish
>> On Tue, 10 Oct 2017, Stefano Zampini wrote:
>> > Satish,
>> > today I had some problems installing PETSc with --download-hypre in
>> batched
>> > mode. Here is my fix
>> > diff --git a/config/BuildSystem/config/packages/hypre.py
>> > b/config/BuildSystem/config/packages/hypre.py
>> > index e374532..3c607c9 100644
>> > --- a/config/BuildSystem/config/packages/hypre.py
>> > +++ b/config/BuildSystem/config/packages/hypre.py
>> > @@ -49,6 +49,9 @@ class Configure(config.package.GNUPackage):
>> >      libs = ' '.join(libs)
>> >      args.append('--with-MPI-libs="'+libs+'"')
>> > +    if self.argDB['with-batch']:
>> > +      args.append('--host')
>> >      # tell hypre configure not to look for blas/lapack [and not use
>> > hypre-internal blas]
>> >  args.append('--with-blas-lib="'+self.libraries.toString(self
>> .blasLapack.dlib)+'"')
>> >      args.append('--with-lapack-lib=" "')
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171010/9da50b38/attachment-0001.html>
