[petsc-dev] DMCoarsenHookAdd in SNESSetUpMatrices
Stefano Zampini stefano.zampini at gmail.com
Mon Oct 2 01:32:15 CDT 2017
Jed,
can you please take a look at this? I don't have any experience on
multilevel SNES and I don't know what is the proper fix
https://bitbucket.org/petsc/petsc/src/40b9351e49c32bd0ef34d75e511ace44084621e9/src/snes/interface/snes.c?at=master&fileviewer=file-view-default#snes.c-645
2017-09-25 18:37 GMT+03:00 Stefano Zampini <stefano.zampini at gmail.com>:
> Jed,
> Today I fought for several hours against a strange behaviour occuring when
> reusing a TS for multiple solves. You can reproduce it by applying the
> attached patch.
> The issue is with DMCoarsenHookAdd called in SNESSetUpMatrices, and git
> blames you ;-).
> Every time you call TSGetRHSMats_Private, TSGetIJacobian gets called,
> which in turns calls SNESSetUpMatrices, that adds the entry in the linked
> list of hooks via DMCoarsenHookAdd. This causes a considerable slow down
> when using the RHS interface with an implicit solver, as you can see from
> running the patched code.
> can you please take a look?
> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171002/c1c4a905/attachment.html>
