[petsc-dev] DMplex: Natural Ordering and subDM
Matthew Knepley
knepley at gmail.com
Mon Nov 27 22:11:44 CST 2017
On Mon, Nov 27, 2017 at 9:24 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Mon, Nov 27, 2017 at 8:08 PM, Jed Brown <jed at jedbrown.org> wrote:
> >> I don't know the answer to your question (Matt?), but do you really need
> >> to reorder the entire mesh or would it be sufficient to label your
> >> points with their original numbering?
> > Maybe I am wrong, but I think it amounts to the same thing. If we are
> going
> > to output things in parallel,
> > we would need to communicate to he writing process, which this
> essentially
> > does.
> Writing a label doesn't require redistribution of the mesh. It's possible
> to do parallel IO.
My understanding is that 3rd party programs want the mesh in the original
order, so we
want it ordered in the HDF5 file in the original order. You could I guess
write it in the order,
but it seems messy to write stuff all over the place in the file. Is that
what you mean?
Matt
> > I thought I responded, but what has to happen is that the SF for this
> > reordering must be decimated to
> > produce a subSF for the subDM. Its just not simple, so I have not had the
> > free time to work it out.
> > Matt
> >> Blaise A Bourdin <bourdin at lsu.edu> writes:
> >> > Hi,
> >> > I am fighting with natural ordering in DMplex with multi-fields /
> multi
> >> components DM.
> >> > I need to read / write files in a distribution-independent ordering.
> The
> >> natural way to do so is to define the natural ordering as that of the
> file,
> >> then call DMPlexGlobalToNaturalBegin/End before VecView:
> >> > The pseudo code would be
> >> > DMPlexCreateFromFile(PETSC_COMM_WORLD,ifilename,
> interpolate,&dmUAS);
> >> > // create default section associated with a complicated layout of
> >> multiple fields
> >> > // (U,\alpha,\sigma)
> >> > DMSetUseNatural(dmUAS,PETSC_TRUE);
> >> > DMPlexDistribute(dmUAS,0,&migrationSF,&dmDist);
> >> > DMGetGlobalVector(dmDist,&UAS);
> >> > DMGetGlobalVector(dmDist,&UASNatural);
> >> > DMPlexGlobalToNaturalBegin(dmDist,UAS,UASNatural);
> >> > DMPlexGlobalToNaturalEnd(dmDist,UAS,UASNatural);
> >> > // Do my I/O stuff using UASNatural
> >> > If I try to do the same thing one field at a time, things break:
> >> > Say that I get the subDM for the first field (U):
> >> > DMCreateSubDM(dmDist,1,&fieldU,&ISU,&dmU);
> >> > Then dmU->useNatural is PETSC_FALSE and I cannot compute
> dmU->sfnatural
> >> using DMPlexCreateGlobalToNaturalSF since I do not have the “sequential”
> >> version of dmU.
> >> > What is the proper way to handle this situation? Creating sequential
> >> subDMs and calling DMDistribute on each of them is ugly and possibly
> costly.
> >> > Regards,
> >> > Blaise
> >> > Department of Mathematics and Center for Computation & Technology
> >> > Louisiana State University, Baton Rouge, LA 70803, USA
> >> > Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276
> http://www.math.lsu.edu/~
> >> bourdin
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> their
> > experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171127/2199f10a/attachment.html>
