[petsc-dev] DMplex: Natural Ordering and subDM
Jed Brown
jed at jedbrown.org
Mon Nov 27 20:08:07 CST 2017
I don't know the answer to your question (Matt?), but do you really need
to reorder the entire mesh or would it be sufficient to label your
points with their original numbering?
Blaise A Bourdin <bourdin at lsu.edu> writes:
> Hi,
> I am fighting with natural ordering in DMplex with multi-fields / multi components DM.
> I need to read / write files in a distribution-independent ordering. The natural way to do so is to define the natural ordering as that of the file, then call DMPlexGlobalToNaturalBegin/End before VecView:
> The pseudo code would be
> DMPlexCreateFromFile(PETSC_COMM_WORLD,ifilename,interpolate,&dmUAS);
> // create default section associated with a complicated layout of multiple fields
> // (U,\alpha,\sigma)
> DMSetUseNatural(dmUAS,PETSC_TRUE);
> DMPlexDistribute(dmUAS,0,&migrationSF,&dmDist);
> DMGetGlobalVector(dmDist,&UAS);
> DMGetGlobalVector(dmDist,&UASNatural);
> DMPlexGlobalToNaturalBegin(dmDist,UAS,UASNatural);
> DMPlexGlobalToNaturalEnd(dmDist,UAS,UASNatural);
> // Do my I/O stuff using UASNatural
> If I try to do the same thing one field at a time, things break:
> Say that I get the subDM for the first field (U):
> DMCreateSubDM(dmDist,1,&fieldU,&ISU,&dmU);
> Then dmU->useNatural is PETSC_FALSE and I cannot compute dmU->sfnatural using DMPlexCreateGlobalToNaturalSF since I do not have the “sequential” version of dmU.
> What is the proper way to handle this situation? Creating sequential subDMs and calling DMDistribute on each of them is ugly and possibly costly.
> Regards,
> Blaise
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
