[petsc-dev] Fwd: [petsc-maint] Could not find a suitable archiver
Matthew Knepley
knepley at gmail.com
Fri Nov 17 15:26:35 CST 2017
Satish is the God of Configure Debugging (consult whole thread, all ye who
enter here)
Matt
---------- Forwarded message ----------
Date: Fri, Nov 17, 2017 at 1:06 PM
Subject: Re: [petsc-maint] Could not find a suitable archiver
To: Patrick Welche <prlw1 at cam.ac.uk>
Cc: petsc-maint <petsc-maint at mcs.anl.gov>
On Fri, 17 Nov 2017, Patrick Welche wrote:
> On Thu, Nov 16, 2017 at 09:24:34PM -0600, Satish Balay wrote:
> > On Fri, 17 Nov 2017, Satish Balay wrote:
> So sorry: when you said "wrappers", I was thinking of f2c - you are
> right about wrappers.
So you are using compiler wrappers [I meant gcc wrapping gcc]
PATH=/tmp/pkgsrc/fenics/petsc/work.x86_64/.cwrapper/bin:/tmp
/pkgsrc/fenics/petsc/work.x86_64/.buildlink/bin:/tmp/pkgsrc/
fenics/petsc/work.x86_64/.gcc/bin:/tmp/pkgsrc/fenics/petsc/
work.x86_64/.tools/bin:/usr/pkg/bin:/home/prlw1/bin:/bin:/
sbin:/usr/bin:/usr/sbin:/usr/X11R7/bin:/usr/X11R6/bin:/usr/
pkg/bin:/usr/pkg/sbin:/usr/games:/usr/local/bin:/usr/local/sbin
bash-4.4# ls /tmp/pkgsrc/fenics/petsc/work/.cwrapper/bin/
as cc clang++ cpp f77 g77 gfortran ld
shlibtool
c++ clang clang-cpp cxx g++ gcc imake
libtool
Ok - lets workarround this.
do-configure:
cd ${WRKSRC} && PATH=/bin:/usr/bin:$PATH ${PYTHONBIN} ./configure
--doCleanup=0 --with-mpi=0 --with-fc=0
Now I go as far as missing blas/lapack.
So the issue is the compile environment that netbsd packaging tools are
setting up.
You'll have to debug why that doesn't work.
Satish
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171117/bc8c86e1/attachment.html>
