[petsc-dev] PETSc blame digest (next) 2017-11-14
Smith, Barry F.
bsmith at mcs.anl.gov
Tue Nov 14 09:10:05 CST 2017
I've fixed this. Used "template" in a C++ program as a variable ;-)
> On Nov 14, 2017, at 9:00 AM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing. Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> to resolve the issues.
> Thanks,
> The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/84a4583
> Fix TSTrajectory handling of directory name and filetemplate
> src/ts/trajectory/impls/basic/trajbasic.c:21
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/14/build_next_arch-osx-10.6-cxx-cmplx-pkgs-dbg_ipro.log]
> /Users/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:21:47: error: expected ';' at end of declaration
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/14/build_next_arch-osx-10.6-cxx-pkgs-opt_ipro.log]
> /Users/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:21:47: error: expected ';' at end of declaration
> /Users/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:21:47: error: expected unqualified-id
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/14/build_next_arch-linux-xsdk-dbg_cg.log]
> /sandbox/petsc/petsc.clone/src/ts/trajectory/impls/basic/trajbasic.c:21:47: error: expected unqualified-id before 'template'
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/14/build_next_arch-linux-gcc-absoft_crank.log]
> /sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:21:47: error: expected unqualified-id before 'template'
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/14/build_next_arch-linux-xsdk-latest_cg.log]
> /sandbox/petsc/petsc.clone-4/src/ts/trajectory/impls/basic/trajbasic.c:21:47: error: expected unqualified-id before 'template'
> /Users/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:21:47: error: expected unqualified-id
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/14/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log]
> /sandbox/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:21:47: error: expected unqualified-id
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/14/build_next_arch-linux-opt-cxx-quad_grind.log]
> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/14/build_next_arch-linux-pkgs-cxx-mlib_el6.log]
> /home/sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:21:47: error: expected unqualified-id before 'template'
> /sandbox/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:21:47: error: expected ';' at end of declaration
> src/ts/trajectory/impls/basic/trajbasic.c:27
> /Users/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:27:40: error: expected expression
> /home/sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:27:40: error: expected ')' before 'template'
> /home/sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:27:40: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone-4/src/ts/trajectory/impls/basic/trajbasic.c:27:24: error: expected primary-expression before 'template'
> /Users/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:27:40: error: expected expression
> /home/sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:27:24: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone/src/ts/trajectory/impls/basic/trajbasic.c:27:40: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone-4/src/ts/trajectory/impls/basic/trajbasic.c:27:40: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone/src/ts/trajectory/impls/basic/trajbasic.c:27:40: error: expected ')' before 'template'
> /sandbox/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:27:24: error: expected expression
> /sandbox/petsc/petsc.clone-4/src/ts/trajectory/impls/basic/trajbasic.c:27:40: error: expected ')' before 'template'
> /sandbox/petsc/petsc.clone/src/ts/trajectory/impls/basic/trajbasic.c:27:24: error: expected primary-expression before 'template'
> /Users/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:27:24: error: expected expression
> /Users/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:27:24: error: expected expression
> /sandbox/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:27:40: error: expected expression
> src/ts/trajectory/impls/basic/trajbasic.c:37
> /sandbox/petsc/petsc.clone/src/ts/trajectory/impls/basic/trajbasic.c:37:52: error: expected primary-expression before 'template'
> /home/sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:37:52: error: expected primary-expression before 'template'
> /Users/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:37:52: error: expected expression
> /Users/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:37:52: error: expected expression
> /sandbox/petsc/petsc.clone-4/src/ts/trajectory/impls/basic/trajbasic.c:37:52: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:37:52: error: expected expression
> src/ts/trajectory/impls/basic/trajbasic.c:44
> /sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:44:50: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:44:50: error: expected expression
> /home/sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:44:50: error: expected primary-expression before 'template'
> /Users/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:44:50: error: expected expression
> /sandbox/petsc/petsc.clone/src/ts/trajectory/impls/basic/trajbasic.c:44:50: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone-4/src/ts/trajectory/impls/basic/trajbasic.c:44:50: error: expected primary-expression before 'template'
> /Users/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:44:50: error: expected expression
> src/ts/trajectory/impls/basic/trajbasic.c:67
> /Users/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:67:47: error: expected ';' at end of declaration
> /sandbox/petsc/petsc.clone/src/ts/trajectory/impls/basic/trajbasic.c:67:47: error: expected unqualified-id before 'template'
> /sandbox/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:67:47: error: expected ';' at end of declaration
> /sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:67:47: error: expected unqualified-id before 'template'
> /Users/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:67:47: error: expected ';' at end of declaration
> /home/sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:67:47: error: expected unqualified-id before 'template'
> /Users/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:67:47: error: expected unqualified-id
> /sandbox/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:67:47: error: expected unqualified-id
> /sandbox/petsc/petsc.clone-4/src/ts/trajectory/impls/basic/trajbasic.c:67:47: error: expected unqualified-id before 'template'
> /Users/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:67:47: error: expected unqualified-id
> src/ts/trajectory/impls/basic/trajbasic.c:71
> /sandbox/petsc/petsc.clone-4/src/ts/trajectory/impls/basic/trajbasic.c:71:40: error: expected ')' before 'template'
> /sandbox/petsc/petsc.clone/src/ts/trajectory/impls/basic/trajbasic.c:71:40: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:71:24: error: expected expression
> /home/sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:71:40: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:71:24: error: expected primary-expression before 'template'
> /home/sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:71:24: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone/src/ts/trajectory/impls/basic/trajbasic.c:71:40: error: expected ')' before 'template'
> /sandbox/petsc/petsc.clone-4/src/ts/trajectory/impls/basic/trajbasic.c:71:40: error: expected primary-expression before 'template'
> /Users/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:71:24: error: expected expression
> /sandbox/petsc/petsc.clone-4/src/ts/trajectory/impls/basic/trajbasic.c:71:24: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone/src/ts/trajectory/impls/basic/trajbasic.c:71:24: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:71:40: error: expected ')' before 'template'
> /sandbox/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:71:40: error: expected expression
> /home/sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:71:40: error: expected ')' before 'template'
> /Users/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:71:40: error: expected expression
> /Users/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:71:40: error: expected expression
> /Users/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:71:24: error: expected expression
> src/ts/trajectory/impls/basic/trajbasic.c:72
> /sandbox/petsc/petsc.clone-4/src/ts/trajectory/impls/basic/trajbasic.c:72:49: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:72:49: error: expected primary-expression before 'template'
> /home/sandbox/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:72:49: error: expected primary-expression before 'template'
> /sandbox/petsc/petsc.clone/src/ts/trajectory/impls/basic/trajbasic.c:72:49: error: expected primary-expression before 'template'
> /Users/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:72:49: error: expected expression
> /Users/petsc/petsc.clone-3/src/ts/trajectory/impls/basic/trajbasic.c:72:49: error: expected expression
> /sandbox/petsc/petsc.clone-2/src/ts/trajectory/impls/basic/trajbasic.c:72:49: error: expected expression
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
