[petsc-dev] broken nightlybuilds (next vs next-tmp)
    Jed Brown
    jed at jedbrown.org
    Sat Nov 11 11:49:22 CST 2017
Matthew Knepley <knepley at gmail.com> writes:
> On Sat, Nov 11, 2017 at 12:37 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Sat, 11 Nov 2017, Matthew Knepley wrote:
>> > > In the long term - Barry wants to get rid of next..
>> > 1) I think next really prevents master from getting screwed up (witness
>> > next)
>> > 2) I think we are actually finding interaction bugs there.
>> > Are those points wrong, or is there another way to do these things?
>> Next is an intergration testing mechanism. The prerequisite for it [I
>> think] is - one should test the branch properly before merging to
>> next. However we are not doing proper testing before merge to next -
>> and relying on next to do this part aswell.
>> So with current next - it one has to figure out which branches are
>> breaking the tests [takes time - which most of us are not doing] - and
>> then hope it gets fixed quickly. Otherwise next stay broken for a long
>> time [and other branches in next - which could be clean - don't
>> receive sufficient confidence to graduate to master]
>> So Barry's thought wrt getting next is to have a better way of testing
>> feature branch one wants to test (i.e master+feature). Its not clear
>> to me how many integration issues we've addressed with our current
>> next model. [Its mostly been indvidual branch issues]
>> Also if feature-1 and feature-2 are feature branches that are tested
>> in next [wrt integration]. The following should be equivalent to
>> testing 'master + feature1 + feature2' - aka current next model:
>> 1. test master+feature1
>> 2. success => merge feature1 to master
>> 3. tets master+ feature2
>> 3. success => merge feature2 to master
>> Note: my next-tmp is an attempt to get closer to 'master+feature1'
>> testing from 'master+feature1+feature2' testing [yeah - its more like
>> master+2/3 branches in next-tmp vs master+10/15 branches in next.]
>> Also I'm restarting next-tmp from a clean master when merging new set
>> of branches to test. And throwing away branches with problems - and
>> retest only after it has fixes [This way a broken branch does not keep
>> next-tmp broken until it gets fixed.]
> I don't think we have the resources to run full tests on every branch one
> at a time. Do we?
No, and after each merge of a branch to 'master', the prospective merge
of other branches would need to be retested.  But the idea that the
automated test suite is infallible is also flawed.
