[petsc-dev] broken nightlybuilds (next vs next-tmp)
Satish Balay
balay at mcs.anl.gov
Sat Nov 11 11:37:15 CST 2017
On Sat, 11 Nov 2017, Matthew Knepley wrote:
> > In the long term - Barry wants to get rid of next..
> 1) I think next really prevents master from getting screwed up (witness
> next)
> 2) I think we are actually finding interaction bugs there.
> Are those points wrong, or is there another way to do these things?
Next is an intergration testing mechanism. The prerequisite for it [I
think] is - one should test the branch properly before merging to
next. However we are not doing proper testing before merge to next -
and relying on next to do this part aswell.
So with current next - it one has to figure out which branches are
breaking the tests [takes time - which most of us are not doing] - and
then hope it gets fixed quickly. Otherwise next stay broken for a long
time [and other branches in next - which could be clean - don't
receive sufficient confidence to graduate to master]
So Barry's thought wrt getting next is to have a better way of testing
feature branch one wants to test (i.e master+feature). Its not clear
to me how many integration issues we've addressed with our current
next model. [Its mostly been indvidual branch issues]
Also if feature-1 and feature-2 are feature branches that are tested
in next [wrt integration]. The following should be equivalent to
testing 'master + feature1 + feature2' - aka current next model:
1. test master+feature1
2. success => merge feature1 to master
3. tets master+ feature2
3. success => merge feature2 to master
Note: my next-tmp is an attempt to get closer to 'master+feature1'
testing from 'master+feature1+feature2' testing [yeah - its more like
master+2/3 branches in next-tmp vs master+10/15 branches in next.]
Also I'm restarting next-tmp from a clean master when merging new set
of branches to test. And throwing away branches with problems - and
retest only after it has fixes [This way a broken branch does not keep
next-tmp broken until it gets fixed.]
Satish
