[petsc-dev] broken nightlybuilds (next vs next-tmp)
Sat Nov 11 11:17:46 CST 2017
On Fri, Nov 10, 2017 at 4:50 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 10 Nov 2017, Richard Tran Mills wrote:
> > Hi Satish,
> > Thanks for taking the initiative to switch to testing next-tmp to help
> > clear up the constipation with moving things into master. It looks like
> > there hasn't been any graduation of the branches you've been putting into
> > next-tmp in a few days, though. Is this just because you haven't had time
> > to do any more of these merges, or are the tests breaking with next-tmp
> now?
> > If I go to the dashboard at
> > http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/
> 2017/11/10/next.html,
> > is this showing me the info for 'next' or 'next-tmp'? If it is showing me
> > 'next', how do I find the results for 'next-tmp'?
> Sorry - I haven't been checking properly on this.
> The last next-tmp build was on:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/07/next.html
> There were some errors - which I didn't debug.
> $ git fetch -p && comm -12 <(git branch -r --merged origin/next-tmp |
> sort) <(git branch -r --no-merged origin/master | sort)
>   origin/hongzh/add-tstraj-filename
>   origin/hongzh/copy_l2g_stencil
>   origin/jed/variadic-malloc
>   origin/rmills/feature-aijmkl-matmatmult
> [Its probably one of the above branches. I'll look for it - and then
> merge the others to master.]
> So I reverted the tests back to next stating 08
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2017/11/08/next.html
> Yeah - next vs next-tmp is not clearly visible here - but if you go to
> any of the logs - you'll see next or next-tmp on the filename.
> For eg:
> 2017/11/07/examples_full_next-tmp.log
> 2017/11/08/examples_full_next.log
> > If we think a branch may be ready for 'master', should we still be
> merging
> > to 'next', given it's current broken state?
> For now - I would say - if you now a bunch of branches that you think
> are ready (master) - I can schedule a next-tmp test on them to verify.
> The tricky thing here is for all of us to be aware of this - and not
> assume next is tested - and merge then go ahead and merge the wrong
> branches to master.
> > Lastly, a question for everyone: If someone knows that they have merged
> > something into 'next' that has broken the builds or tests, and it is
> going
> > to be a while before this is fixed, should they revert that changeset in
> > 'next'? I see some reverts in the 'next' logs, but not that many. Maybe
> > this is because it's not always easy to tell if one's particular
> changeset
> > broke things when there are all these other changes being merged.
> Reverts are tricky - hence I avoid them. But if needed - we could do
> that [it requires extra care in the workflow - i.e when you have to
> merge back later - or revert again for the second time etc.]
> Alternative is to delete/recreate next - if needed. [but it requires
> all next users to do this delete/recreation]
> In the long term - Barry wants to get rid of next..
1) I think next really prevents master from getting screwed up (witness
next)
2) I think we are actually finding interaction bugs there.
Are those points wrong, or is there another way to do these things?
     Matt
> Satish
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171111/a8f5d72a/attachment.html>
