[petsc-dev] composite vs. shell
Jed Brown
jed at jedbrown.org
Fri Nov 10 15:36:07 CST 2017
"Smith, Barry F." <bsmith at mcs.anl.gov> writes:
>>> Jed,
>>> Please articulate in a bit more detail. From what I can interpolate you are saying
>>> 1) that if we only propagate the outer matrices to inner matrices that the user has not set we will get a better more intuitive interface for users
>>> but
>>> 2) the whole idea of propagating in is probably flawed.
>> The idea of having only two matrices, Amat and Pmat, is flawed.
> Yes
>> A
>> composite preconditioner, for example, may need more. Having users
>> unwrap solvers to manually set matrices is ugly, but in lieu of a better
>> way (like named auxiliary matrices that can be requested by nested
>> preconditioners), we should honor the user's manual choices.
> Yes.
> But you are not directly answering my question. Should we change
> the code to not propagate if already set?
Yes, I think so. That is what I meant by "we should honor the user's
manual choices" above.
