[petsc-dev] PR #800
Vaclav Hapla
vaclav.hapla at erdw.ethz.ch
Fri Nov 10 05:25:25 CST 2017
Hi Matt
I would like to redirect the changes in PR #800 "DMPlex ex5 set partitioner from options" into maint so that we have a test base for fixing the PETSCPARTITIONERPARMETIS bug below, mentioned in the other thread. I feel this should fixed anyway, independently of the proposed PETSCPARTITIONERMATPARTITIONING which will take some time.
So if you agree, I decline current PR #800, and prepare a new one targeted to main.
src/dm/impls/plex/examples/tutorials/ex5.c fails with partitioner set to PETSCPARTITIONERPARMETIS for certain numbers of processes
[ 0] ***ASSERTION failed on line 176 of file /scratch/petsc-dev/arch-linux-gcc-salvus/externalpackages/git.parmetis/libparmetis/comm.c: j == nnbrs
[ 2] ***ASSERTION failed on line 176 of file /scratch/petsc-dev/arch-linux-gcc-salvus/externalpackages/git.parmetis/libparmetis/comm.c: j == nnbrs
ex5: /scratch/petsc-dev/arch-linux-gcc-salvus/externalpackages/git.parmetis/libparmetis/comm.c:176: libparmetis__CommSetup: Assertion `j == nnbrs' failed.
Thanks
Vaclav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171110/17e87dcd/attachment.html>
