[petsc-dev] DMPlexCreateMedFromFile broken
Matthew Knepley
knepley at gmail.com
Thu Nov 9 12:35:32 CST 2017
On Thu, Nov 9, 2017 at 11:15 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
wrote:
> 7. 11. 2017 v 19:51, Matthew Knepley <knepley at gmail.com>:
> On Tue, Nov 7, 2017 at 11:44 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
> wrote:
>> Nico Schlömer just introduced MED support into his meshio tool, based on
>> my issue request. When I convert blockcylinder-50.exo directly to the MED
>> format with meshio, the result can be loaded into GMSH and looks
>> reasonable. But DMPlexCreateMedFromFile denies to open it with the
>> following error:
>> _MEDmeshAdvancedRd236.c [285] : Erreur de valeur invalide du filtre
>> _MEDmeshAdvancedRd236.c [286] : geotype = 0
>> _MEDmeshAdvancedRd236.c [286] : meshname = "mesh0"
>> _MEDmeshAdvancedRd236.c [286] : _datagroupname2 = "NOE"
>> _MEDmeshAdvancedRd236.c [287] : (*_filter).storagemode = 2
>> [0]PETSC ERROR: #1 DMPlexCreateMedFromFile() line 86 in
>> /scratch/petsc-dev/src/dm/impls/plex/plexmed.c
>> [0]PETSC ERROR: #2 DMPlexCreateFromFile() line 2815 in
>> /scratch/petsc-dev/src/dm/impls/plex/plexcreate.c
>> [0]PETSC ERROR: #3 main() line 38 in /scratch/petsc-dev/src/dm/impl
>> s/plex/examples/tutorials/ex5.c
>> Can you see whether it's a bug in DMPlexCreateMedFromFile or the MED file
>> is broken?
> It appears to be an MED incompatibility
> https://bitbucket.org/petsc/petsc/src/17bd883d72f40a596f2d89b5afda5a
> 233b621464/src/dm/impls/plex/plexmed.c?at=master&
> fileviewer=file-view-default#plexmed.c-86
> We should ask Nico about it.
> I tried to load the MED file from meshio (attached) by the MED-supplied
> test $PETSC_ARCH/externalpackages/med-3.2.0/tests/c/test5.c, and it
> didn't complain. I compared it with DMPlexCreateMedFromFile, replaced
> MED_COMPACT_STMODE flag by MED_GLOBAL_PFLMODE in MEDfilterBlockOfEntityCr
> calls (patch attached), and it started to work magically.
The people who write MED should be shot, or at least severely beaten so
they can still document this stuff. Here is code using COMPACT
https://github.com/cycheung/gmsh/blob/master/Post/PViewDataGModelIO.cpp#L581
I am reluctant to change things without a reason.
Matt
> But I have no idea what's the meaning of this flag - I found no
> documentation of the MED library.
> Note also that your knepley/fix-plex-med-orientation fix is still needed
> so I mean this should be applied generally - Nico's meshio is independent
> of GMSH.
> Vaclav
> Thanks,
> Matt
>> Thanks
>> Vaclav
>> 5. 11. 2017 v 18:48, Matthew Knepley <knepley at gmail.com>:
>> On Thu, Nov 2, 2017 at 12:08 PM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
>> wrote:
>>> It seems that DMPlexCreateMedFromFile leaves out some mesh elements. I
>>> found it out when investigating why ParMetis redistribution crashes.
>>> I attach the datafile $PETSC_DIR/share/petsc/datafiles/meshes/blockcylinder-50.exo
>>> converted to GMSH and MED format.
>>> The conversion EXO to GMSH was done by meshio (github.com/nschloe/meshio),
>>> and GMSH to MED by GMSH itself.
>>> I did:
>>> cd $PETSC_DIR/src/dm/impls/plex/examples/tutorials
>>> make ex5
>>> FILE=blockcylinder-50.exo && ./ex5 -filename $FILE -dm_view
>>> hdf5:$FILE.h5 && $PETSC_DIR/bin/petsc_gen_xdmf.py $FILE.h5
>>> FILE=blockcylinder-50.msh && ./ex5 -filename $FILE -dm_view
>>> FILE=blockcylinder-50.med && ./ex5 -filename $FILE -dm_view
>>> While the output from blockcylinder-50.exo and blockcylinder-50.msh
>>> looks OK, that from blockcylinder-50.med is corrupted.
>>> I also attach my HDF5/XDMF outputs and screenshots from ParaView.
>> It appears that MED, at least coming from GMsh, inverts hexes just like
>> GMsh does. I have fixed this in branch
>> If you run your test in this, everything should be fine.
>> Michael, can you check whether this is a general fix, or it only applied
>> to MED from GMsh?
>> Thanks,
>> Matt
>>> Vaclav
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171109/2f91c45f/attachment.html>
