[petsc-dev] proposed minor PetscPartitioner changes
Matthew Knepley
knepley at gmail.com
Wed Nov 8 13:42:14 CST 2017
On Wed, Nov 8, 2017 at 2:27 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> >> > No, this is the right structure.
> >> >> Oh come on. You're defending a quadratic algorithm.
> >> >> ierr = ParMETIS_V3_PartKway(vtxdist, xadj, adjncy, vwgt,
> adjwgt,
> >> >> &wgtflag, &numflag, &ncon, &nparts, tpwgts, ubvec, options, &edgeCut,
> >> >> assignment, &comm);
> >> >> for (p = 0, i = 0; p < nparts; ++p) {
> >> >> for (v = 0; v < nvtxs; ++v) {
> >> >> if (assignment[v] == p) points[i++] = v;
> >> >> MatPartitioningApply creates an IS with "assignment" and can be
> >> >> converted to a global numbering with ISPartitioningToNumbering. You
> >> >> could as well have an ISPartitioningToSectionAndIS() that produces
> your
> >> >> representation, preferably without this silly quadratic algorithm.
> >> > Time it. Tell me if it matters. Telling me it matters in the long run
> is
> >> > metaphysics.
> >> I realize ParMETIS isn't scalable and that if you have a modest number
> >> of parts and only a million or so elements per rank, the cost of what
> >> you do here will be acceptable for most uses.
> >> But you didn't refute my point that ISPartitioningToSectionAndIS can
> >> produce the representation you want.
> > I do not think its an either or thing. Many equivalent interfaces are
> > possible,
> > so I should have told Vaclav "I think this is the right one", but I
> thought
> > that
> > was implicit in me being the responder, and none of us thinking that
> there
> > is
> > a true "right" in interface design.
> >> The IS you're creating is similar
> >> to the inverse of the Numbering (which is a permutation). You are the
> >> one that replaced a scalable algorithm that has existed for a long time
> >> and uses types correctly with PetscPartitioner which has some ugly
> >> warts, duplicates a lot of code, and isn't a viable replacement for
> >> MatPartitioning.
> > 1) MatPartitioning is not a replacement for what I do. According to you,
> > that
> > should end the argument right there.
> > 2) Deep inside MatPartitioning, it must split things up as I do in order
> to
> > pack
> > stuff to be sent. I think it should be exposed as I have done.
> Pack what stuff to be sent? PetscPartitionerPartition() takes the
> arguments to ParMETIS directly as arrays. To use MatPartitioning, you
> pass those same arrays to MatCreateMPIAdj which literally just holds the
> pointers. Then MatPartitioningApply passes those on to ParMETIS or
> whichever partitioning package. PetscPartitionerPartition_*
> implementations depends on DM strictly as a way to define the weights.
> That isn't more general or better; it's more restrictive.
This sounds like deliberate misunderstanding. We are not talking about the
input to
ParMetis, but the output. The biggest shortcoming of ParMetis (and indeed
all mesh
partitioners) is that they tell you what must move, but do not move it.
This is the value
add of Plex, it moves the mesh (including all connectivity) and the field
data according
to the partition. In order to do this communication, you always want the
partition segmented
by rank, as it is in the Section/IS output.
> I see no reason why PetscPartitioner cannot be implemented as a very
> small amount of code around MatPartitioning (little more than the
> interface function). The opposite would necessarily bring in concepts
> like DM that are unnecessary when a user is partitioning matrices and
> graphs.
I am not arguing that it should not be done. I am saying
- I do not want to do it, because the payoff is small
- I do not want it to break anything that currently works
- I do not want it to break the interface we currently have to
PetscPartitioner because I think it is genuinely good
> > 3) I think you exaggerate the faults of the code for effect. Do what you
> > must.
> >> And now you seem to be arguing against Vaclav unifying
> >> it, claiming technical rationale that don't appear to hold up.
> > Of course, I disagree with you, and think you make no attempt to
> understand
> > why
> > someone would write this code, because you never solve the problems its
> > necessary
> > for.
> I have written a parallel unstructured FEM that did this sort of
> partitioning and redistribution on the fly. I wrote it in terms of
> MatPartitioning and it worked fine. I abandoned it because it had
> screwy dependencies and you had abandoned Sieve to work on
> DMComplex/DMPlex. I'm happy to have made that change, but the concepts
> and requirements are hardly foreign to me.
Worked fine for you :) It always different with other people.
>> I don't
> >> understand why, but it certainly looks like PetscPartitioner can be
> >> implemented as a thin layer around MatPartitioning, then that layer can
> >> be refactored into helper functions at the IS/PetscSection level.
> > It might be true. To me, it looked like Mat stuff was draped on so it
> would
> > be hard
> > to pull the raw result out of the partitioner, and that things would get
> > created (like
> > the MatMult Scatter) which I did not want.
> Barry created the MPIADJ representations in 1997 precisely for this
> purpose.
Fair.
Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171108/b259d9aa/attachment-0001.html>
