[petsc-dev] proposed minor PetscPartitioner changes
    Matthew Knepley
    knepley at gmail.com
    Wed Nov  8 12:11:43 CST 2017
On Wed, Nov 8, 2017 at 1:02 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Wed, Nov 8, 2017 at 10:04 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch
> > wrote:
> >> 8. 11. 2017 v 15:59, Matthew Knepley <knepley at gmail.com>:
> >> On Wed, Nov 8, 2017 at 9:14 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch
> >> wrote:
> >>> 8. 11. 2017 v 14:52, Jed Brown <jed at jedbrown.org>:
> >>> On Wed, Nov 8, 2017 at 4:52 AM, Vaclav Hapla <
> vaclav.hapla at erdw.ethz.ch>
> >>> wrote:
> >>> 8. 11. 2017 v 9:06, Lisandro Dalcin <dalcinl at gmail.com>:
> >>> On 8 November 2017 at 05:51, Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >>> On Nov 7, 2017, at 1:33 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> >>> The only concern I have about PetscPartitioner is that the API depends
> >>> on DM (PetscPartitionerPartition_<TYPE> routines). Maybe
> >>> PetscPartitioner should eventually move to became more agnostic, and
> >>> that way it can be used to partition matrices and meshes.
> >>>  This is certainly a serious flaw if PetscPartitioner is intended as
> >>> THE API to use for partitioning. If it is not intended as THE API for
> >>> partitioning then that is also a problem, because why have multiple
> APIs
> >>> for what is essentially one set of abstractions.
> >>> Note however that things looks easy to refactor. I'll try to team up
> >>> with Matt to improve things.
> >>> Wait, now we are at the beginning again. I actually wanted to do some
> >>> refactoring of PetscPartitioner, starting with few cosmetic changes to
> >>> make
> >>> it better settable from options. But Barry kept me back of any edits
> since
> >>> he think it's anti-systematic to keep two independent classes doing
> >>> essentially the same. And I agree with that to be honest. It's strange
> to
> >>> have two ParMetis, two Scotch and two whatever interfaces. The only
> thing
> >>> I
> >>> don't like on MatPartitioning is its name as it's not just for Mat
> >>> Partitioning :-)
> >>> There are from my point of view multiple issues with PetscPartitioner.
> >>> Let's look e.g. at PetscPartitionerPartition. It takes as arguments
> both
> >>> PetscPartitioner and DM. This DM must be in fact DMPlex which is not
> >>> checked so it will probably crash somewhere deep in the stack once the
> >>> first DMPlex specific line is reached. Then there are two output
> arguments
> >>> PetscSection partSection and IS *partition. The first must be created
> >>> beforehand while the second is created inside. And I guess they must
> keep
> >>> the same basic information just in two different forms.
> >>> This is wrong.
> >>> Matt, do you mean what I wrote above is not true (then I'm going to
> prove
> >>> that it's true), or the opposite that the PetscPartitionerPartition
> design
> >>> is actually not good :-)
> >> I meant "they must keep the same basic information just in two different
> >> forms" is wrong (I had to leave for work). The Section gives offsets for
> >> each partition, and the IS stores the actual points being sent.
> >> OK, now I see. And do you think the Section could be somehow computed
> from
> >> just the IS?
> > No, this is the right structure.
> Oh come on.  You're defending a quadratic algorithm.
>       ierr = ParMETIS_V3_PartKway(vtxdist, xadj, adjncy, vwgt, adjwgt,
> &wgtflag, &numflag, &ncon, &nparts, tpwgts, ubvec, options, &edgeCut,
> assignment, &comm);
>   for (p = 0, i = 0; p < nparts; ++p) {
>     for (v = 0; v < nvtxs; ++v) {
>       if (assignment[v] == p) points[i++] = v;
> MatPartitioningApply creates an IS with "assignment" and can be
> converted to a global numbering with ISPartitioningToNumbering.  You
> could as well have an ISPartitioningToSectionAndIS() that produces your
> representation, preferably without this silly quadratic algorithm.
Time it. Tell me if it matters. Telling me it matters in the long run is
metaphysics.
   Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171108/76fcac8c/attachment.html>
