[petsc-dev] proposed minor PetscPartitioner changes
    Vaclav Hapla
    vaclav.hapla at erdw.ethz.ch
    Wed Nov  8 09:04:44 CST 2017
> 8. 11. 2017 v 15:59, Matthew Knepley <knepley at gmail.com>:
> On Wed, Nov 8, 2017 at 9:14 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>> wrote:
>> 8. 11. 2017 v 14:52, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>>:
>> Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> writes:
>>> On Wed, Nov 8, 2017 at 4:52 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch <mailto:vaclav.hapla at erdw.ethz.ch>>
>>> wrote:
>>>>> 8. 11. 2017 v 9:06, Lisandro Dalcin <dalcinl at gmail.com <mailto:dalcinl at gmail.com>>:
>>>>> On 8 November 2017 at 05:51, Smith, Barry F. <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
>>>>>>> On Nov 7, 2017, at 1:33 AM, Lisandro Dalcin <dalcinl at gmail.com <mailto:dalcinl at gmail.com>> wrote:
>>>>>>> The only concern I have about PetscPartitioner is that the API depends
>>>>>>> on DM (PetscPartitionerPartition_<TYPE> routines). Maybe
>>>>>>> PetscPartitioner should eventually move to became more agnostic, and
>>>>>>> that way it can be used to partition matrices and meshes.
>>>>>>  This is certainly a serious flaw if PetscPartitioner is intended as
>>>> THE API to use for partitioning. If it is not intended as THE API for
>>>> partitioning then that is also a problem, because why have multiple APIs
>>>> for what is essentially one set of abstractions.
>>>>> Note however that things looks easy to refactor. I'll try to team up
>>>>> with Matt to improve things.
>>>> Wait, now we are at the beginning again. I actually wanted to do some
>>>> refactoring of PetscPartitioner, starting with few cosmetic changes to make
>>>> it better settable from options. But Barry kept me back of any edits since
>>>> he think it's anti-systematic to keep two independent classes doing
>>>> essentially the same. And I agree with that to be honest. It's strange to
>>>> have two ParMetis, two Scotch and two whatever interfaces. The only thing I
>>>> don't like on MatPartitioning is its name as it's not just for Mat
>>>> Partitioning :-)
>>>> There are from my point of view multiple issues with PetscPartitioner.
>>>> Let's look e.g. at PetscPartitionerPartition. It takes as arguments both
>>>> PetscPartitioner and DM. This DM must be in fact DMPlex which is not
>>>> checked so it will probably crash somewhere deep in the stack once the
>>>> first DMPlex specific line is reached. Then there are two output arguments
>>>> PetscSection partSection and IS *partition. The first must be created
>>>> beforehand while the second is created inside. And I guess they must keep
>>>> the same basic information just in two different forms.
>>> This is wrong.
> Matt, do you mean what I wrote above is not true (then I'm going to prove that it's true), or the opposite that the PetscPartitionerPartition design is actually not good :-)
> I meant "they must keep the same basic information just in two different forms" is wrong (I had to leave for work). The Section gives offsets for
> each partition, and the IS stores the actual points being sent.
OK, now I see. And do you think the Section could be somehow computed from just the IS?
Thanks
Vaclav
>    Matt
> Vaclav
>> Dude, this isn't how we interaction here.  If there is a technical
>> reason why what Vaclav, Lisandro, and Barry want to do cannot work, you
>> should explain that.  Just casting doubt without working toward a
>> solution is not okay.
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171108/f5009143/attachment-0001.html>
