[petsc-dev] proposed minor PetscPartitioner changes
Matthew Knepley
knepley at gmail.com
Wed Nov 8 07:44:27 CST 2017
On Wed, Nov 8, 2017 at 4:52 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch>
wrote:
> > 8. 11. 2017 v 9:06, Lisandro Dalcin <dalcinl at gmail.com>:
> > On 8 November 2017 at 05:51, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> >>> On Nov 7, 2017, at 1:33 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> >>> The only concern I have about PetscPartitioner is that the API depends
> >>> on DM (PetscPartitionerPartition_<TYPE> routines). Maybe
> >>> PetscPartitioner should eventually move to became more agnostic, and
> >>> that way it can be used to partition matrices and meshes.
> >> This is certainly a serious flaw if PetscPartitioner is intended as
> THE API to use for partitioning. If it is not intended as THE API for
> partitioning then that is also a problem, because why have multiple APIs
> for what is essentially one set of abstractions.
> > Note however that things looks easy to refactor. I'll try to team up
> > with Matt to improve things.
> Wait, now we are at the beginning again. I actually wanted to do some
> refactoring of PetscPartitioner, starting with few cosmetic changes to make
> it better settable from options. But Barry kept me back of any edits since
> he think it's anti-systematic to keep two independent classes doing
> essentially the same. And I agree with that to be honest. It's strange to
> have two ParMetis, two Scotch and two whatever interfaces. The only thing I
> don't like on MatPartitioning is its name as it's not just for Mat
> Partitioning :-)
> There are from my point of view multiple issues with PetscPartitioner.
> Let's look e.g. at PetscPartitionerPartition. It takes as arguments both
> PetscPartitioner and DM. This DM must be in fact DMPlex which is not
> checked so it will probably crash somewhere deep in the stack once the
> first DMPlex specific line is reached. Then there are two output arguments
> PetscSection partSection and IS *partition. The first must be created
> beforehand while the second is created inside. And I guess they must keep
> the same basic information just in two different forms.
This is wrong.
Matt
> Actually the original problem I wanted to solve is that
> src/dm/impls/plex/examples/tutorials/ex5.c fails with partitioner set to
> PETSCPARTITIONERPARMETIS for certain numbers of processes, see below. Let
> me start with pull request altering ex5.c so that partitioner type can be
> set from options properly and this bug can be reproduced easily.
> [ 0] ***ASSERTION failed on line 176 of file /scratch/petsc-dev/arch-linux-
> gcc-salvus/externalpackages/git.parmetis/libparmetis/comm.c: j == nnbrs
> [ 2] ***ASSERTION failed on line 176 of file /scratch/petsc-dev/arch-linux-
> ex5: /scratch/petsc-dev/arch-linux-gcc-salvus/externalpackages/
> git.parmetis/libparmetis/comm.c:176: libparmetis__CommSetup: Assertion `j
> == nnbrs' failed.
> == nnbrs' failed.
> I'm wondering whether the MatPartitioning interface has the same problem.
> But anyhow I mean it's maybe time to decide about the two interfaces before
> chasing all these PetscPartitioner issues.
> I propose
> - to rename Mat Partitioning to just Partitioning/-er or take over the
> name PetscPartitioner,
> - what is now PetscPartitioner would be MeshPartitioning/-er and it would
> become sort of adapter from DMPlex meshes to general graphs so that the
> more general class above can be employed.
> Note that I created an issue request as Barry suggested (#192) but there's
> no feedback yet.
> Note my top level intention is to chip in some more distributed mesh
> loaders - currently there's only one for Salome/MED format which is rather
> non-standard and not much documented.
> Thanks
> Vaclav
> > Lisandro Dalcin
> > Research Scientist
> > Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> > Extreme Computing Research Center (ECRC)
> > King Abdullah University of Science and Technology (KAUST)
> > http://ecrc.kaust.edu.sa/
> > 4700 King Abdullah University of Science and Technology
> > al-Khawarizmi Bldg (Bldg 1), Office # 0109
> > Thuwal 23955-6900, Kingdom of Saudi Arabia
> > http://www.kaust.edu.sa
> > Office Phone: +966 12 808-0459
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171108/c1624b13/attachment.html>
