[petsc-dev] proposed minor PetscPartitioner changes
Lisandro Dalcin
dalcinl at gmail.com
Wed Nov 8 02:06:41 CST 2017
On 8 November 2017 at 05:51, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>> On Nov 7, 2017, at 1:33 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> The only concern I have about PetscPartitioner is that the API depends
>> on DM (PetscPartitionerPartition_<TYPE> routines). Maybe
>> PetscPartitioner should eventually move to became more agnostic, and
>> that way it can be used to partition matrices and meshes.
> This is certainly a serious flaw if PetscPartitioner is intended as THE API to use for partitioning. If it is not intended as THE API for partitioning then that is also a problem, because why have multiple APIs for what is essentially one set of abstractions.
Note however that things looks easy to refactor. I'll try to team up
with Matt to improve things.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 0109
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
