[petsc-dev] proposed minor PetscPartitioner changes
Smith, Barry F.
bsmith at mcs.anl.gov
Mon Nov 6 07:37:08 CST 2017
> On Nov 6, 2017, at 7:30 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch> wrote:
>> 6. 11. 2017 v 14:27, Matthew Knepley <knepley at gmail.com>:
>> On Mon, Nov 6, 2017 at 8:24 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>> Vaclav,
>> Actually you should not just do this! PETSc already has a full class for managing partitioning (that Matt ignored for no good reason)
>> Obviously, a good reason existed. All sorts of horrible Mat-specific crap was in these. It was impossible to use for mesh partitioning. In addition,
>> when partitioning meshes, you need extra things (like calculation of the dual graph), which is not used in the matrix case.
> This is what I thought; mesh and matrix partitioning is quite a different task to me, although typically using the same low-level libraries.
Vaclav,
MatPartitioning is not just for partitioning Mats, it is for partitioning graphs. Please look at the code, you'll see Matt duplicated tons of it in doing his own "mesh partitioning" stuff and all that code duplication is a sign that they really are not "quite a different task".
Barry
> Vaclav
>> Matt
>> see MatPartitioningCreate(). Please look at all the functionality before doing anything.
>> Any refactorization you do needs to combine, simplify, and cleanup the two interfaces to create one simpler one. And please let us know your design ideas (with for example an issue on bitbucket) before you go ahead and write a lot of code we may end up not liking.
>> Thanks for looking at this,
>> Barry
>> > On Nov 6, 2017, at 7:09 AM, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch> wrote:
>> > Hello
>> > The whole PetscPartitioner class sources are part of src/dm/impls/plex/plexpartition.c, mixed together with some DMPlex* functions.
>> > If you don't mind, I would move the PetscPartitioner* stuff into the separate file petscpartitioner.c
>> > (in future, it could be even moved to a separate directory).
>> > I would also like to
>> > * add PetscPartitioner{Add,Set,Get}OptionsPrefix,
>> > * create the partitioner lazily in DMPlexGetPartitioner, followed by PetscObjectIncrementTabLevel, PetscLogObjectParent and PetscPartitionerSetOptionsPrefix calls,
>> > * edit src/dm/impls/plex/examples/tutorials/ex5.c so that it calls DMSetFromOptions right after DMPlexCreateFromFile, in order to make the partitioner changeable from options.
>> > Do you have anything against?
>> > Vaclav
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
