[petsc-dev] CMake: make, install, find_package ?
Franck Houssen franck.houssen at inria.fr
Sun Nov 5 09:41:22 CST 2017
Here is a bundle you can pull for you to have a look (franck/cmake branch - push KO to the bitbucket as I don't know which loggin/password to use): take it or leave it ! :D
On debian, I have a "real" cmake build (not the configure traces) in a dedicated BUILD directory (make things cleaner).
More important: getting find_package to work will be much more reliable than resorting to FindPETSc.cmake (often KO as architecture/OS specific...).
I would understand you give up with CMake for reason of your own reason (!)...
But if so, the simple presence of CMakeLists.txt may be misleading (personal opinion: people can go "let's try to use it".).
Hope this helps !...
Franck
/petsc> ./configure; mkdir BUILD; cd BUILD; cmake -DPETSc_CMAKE_ARCH=arch-linux2-c-opt -DCMAKE_INSTALL_PREFIX=/tmp/local ..; make; make install
-- Configuring done
-- Generating done
-- Build files have been written to: /home/fghoussen/Documents/INRIA/petsc/BUILD
Scanning dependencies of target petsc
[  0%] Building Fortran object CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o
[  0%] Building Fortran object CMakeFiles/petsc.dir/src/vec/f90-mod/petscvecmod.F.o
----- Mail original -----
> De: "Satish Balay" <balay at mcs.anl.gov>
> À: "Franck Houssen" <franck.houssen at inria.fr>
> Cc: "petsc-dev" <petsc-dev at mcs.anl.gov>, "Jed Brown" <jed at jedbrown.org>
> Envoyé: Dimanche 5 Novembre 2017 15:52:44
> Objet: Re: [petsc-dev] CMake: make, install, find_package ?
> On Sun, 5 Nov 2017, Franck Houssen wrote:
> > > Or are you having trouble with
> > > https://github.com/jedbrown/cmake-modules/blob/master/FindPETSc.cmake ?
> > > [and not with PETSc build?]
> > At first, I was trying to understand why find_package(petsc) was not
> > working.
> > So then, I looked at the way the make/install was done: that lead me to
> > look at the CMakeLists.txt and test it.
> > > > What did not work for you? Please send relavent logs.
> > Didn't find mpi.mod.
> > find_package(MPI) was missing: I just added it.
> > Still can push if you want to have a look (?).
> So your primary issue is with FindPETSc.cmake - and the fix you have is for
> petsc?
> Sure post the patch or push [where?] and Jed might review..
> Instructions to reproduce the problem will help.
> Satish
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171105/bc037841/attachment.obj>
