[petsc-dev] Recover from TS failure
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Nov 2 11:21:04 CDT 2017
> On Nov 1, 2017, at 1:13 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Yea, I don't understand the linear solve error:
> -ts_monitor -ts_type beuler -pc_type lu -pc_factor_mat_solver_package mumps -ksp_type preonly -snes_monitor -snes_rtol 1.e-10 -snes_stol 1.e-10 -snes_converged_reason -snes_atol 1.e-18 -snes_converged_reason
> Maybe mumps?
> On Wed, Nov 1, 2017 at 2:02 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> >> > I have added some code in a TS post step method to look at the number of
> >> > nonlinear iterations and cut the time step if it took too many SNES
> >> > iterations. That helped but now I want to go one step further and
> >> recover
> >> > from a failed time step (see appended error message).
> >> > How can/should I recover from a SNES failure inside of TS? I could just
> >> put
> >> > TSSolve in a loop and if TS failed because of the solver, then reduce the
> >> > time step and try to recover the state, and try again.
This is absolute nonsense. No way should you or do you need to do this. TS can/is suppose to handle failures in the solver cleanly. We need a reproducible result where it does not handle it correctly and then we fix the problem
> >> > Thoughts?
> >> > Thanks,
> >> > Mark
> >> > Note, this is a direct solver and the linear solver is diverging? I've
> >> > seen the same thing with the maximum its in SNES and failed linesearch.
> >> > 23 TS dt 0.0025 time 0.1025
> >> > 0 SNES Function norm 9.997473571601e+04
> >> > 1 SNES Function norm 2.295851692533e-01
> >> > Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE
> >> iterations 1
> >> > [0]PETSC ERROR: --------------------- Error Message
> >> > [0]PETSC ERROR:
> >> > [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE,
> >> increase
> >> > -ts_max_snes_failures or make negative to attempt recovery
> >> Did you increase -ts_max_snes_failures (TSSetMaxSNESFailures)?
> > Ah, read the error message :) with a negative value I get this.
> > TS can not, or is not going to try, to reconstruct my state and reduce the
> > time step. So I think I need to do this myself.
> I don't understand. Why is the linear solve diverging
> (-ksp_converged_reason)? What TS are you using?
> > I guess just making loop and testing in the TSConvergedReason, is the way
> > to go. We already do something like this for mesh adpativity.
> > Thanks,
> > Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 1
> > Nonlinear solve did not converge due to DIVERGED_LINEAR_SOLVE iterations 0
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: TSStep has failed due to DIVERGED_STEP_REJECTED
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
> > trouble shooting.
> > [0]PETSC ERROR: Petsc Development GIT revision: v3.8-53-ga2d93b2d43 GIT
> > Date: 2017-10-09 12:56:49 -0400
> > [0]PETSC ERROR: ./ex48 on a arch-macosx-gnu-O named MarksMac-5.local by
> > markadams Wed Nov 1 13:51:24 2017
> > [0]PETSC ERROR: Configure options --with-cc=clang --with-cc++=clang++
> > COPTFLAGS="-O2 -g -mavx2" CXXOPTFLAGS="-O2 -g -mavx2" FOPTFLAGS="-O2 -g
> > -mavx2" --download-mpich=1 --download-parmetis=1 --download-metis=1
> > --download-hypre=1 --download-ml=1 --download-triangle=1
> > --download-ctetgen=1 --download-p4est=1 --download-fftw --download-mumps=1
> > --download-scalapack=1 --with-x=0 --download-superlu_dist
> > --download-superlu --download-ctetgen --with-debugging=0 --download-hdf5=1
> > PETSC_ARCH=arch-macosx-gnu-O --download-chaco --with-viewfromoptions=1
> > [0]PETSC ERROR: #1 TSStep() line 4130 in
> > /Users/markadams/Codes/petsc/src/ts/interface/ts.c
> > [0]PETSC ERROR: #2 TSSolve() line 4374 in
> > *********** DIVERGED_STEP_REJECTED ierr=91 reason=-2
> > L_2 Diff: 1.32241e+07 at time 0.1025
> >> for
> >> > trouble shooting.
> >> > markadams Wed Nov 1 13:17:15 2017
> >> --download-mumps=1
> >> --download-hdf5=1
> >> > [0]PETSC ERROR: #1 TSStep() line 4129 in
> >> > [0]PETSC ERROR: #3 main() line 1161 in /Users/markadams/Codes/mhd/
> >> src/ex48.c
