[petsc-dev] Recover from TS failure
Mark Adams
mfadams at lbl.gov
Wed Nov 1 21:22:35 CDT 2017
On Wed, Nov 1, 2017 at 8:30 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> >> The last relevant output you've shown me is SNES failing a bunch of
> >> times as the adaptive controller attempts to shrink the step size and
> >> retry. If you fixed that problem, you need to tell me. If not, THAT is
> >> the problem you need to fix.
> > That is the problem I am trying to fix.
> The solution to that isn't on the outside.
Does the "inside" exist or is there simply not a proof that it does not
exist?
> > Note, I am also adapting the time step when the solver converges but
> > talks a lot of iterations. Thus, no need for recovery.
> You can encapsulate that in an adaptive controller or put the logic (to
> get the SNES iteration number and decided whether to TSSetTimeStep) in
> the TS PostStep function.
That is what I do, and it is fine. It works well enough, I now am trying to
deal with TS failure.
> > It is the SNES failure, recover, cut time step, try again, that I am
> > working in now.
> That is already running in the TSAdapt. Your failure is a result of
> something else. Use -ts_adapt_monitor for more diagnostics about the
> controller's decisions.
I looked at TSAdapt for the first problem, of adapting when this look bad
but work. It failed because its algo was not quite right for this problem.
So I put a simple algo in a post step method.
Can TSAdapt deal with a SNES failure, recover, cut time step, and rerun the
step?
> >> Did you read about -ts_error_if_step_fails on the man page
> > Google, and found the command line args
> >> for the
> >> functional interface I just cited?
> > Sorry, I missed this cite and used 'git grep' to see that it was there
> > (Matt sent me the SNES version today so I knew what to look for).
> >> >> but all the logic you're talking about is already in TS and
> >> >> jury-rigging it on the outside is counterproductive. So get back to
> >> >> the root of the problem and debug why SNES is failing.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171101/833a25d4/attachment-0001.html>
