[petsc-dev] One DM two SNES
Blaise A Bourdin
bourdin at lsu.edu
Wed Nov 1 17:50:17 CDT 2017
I have just spent 2h helping a student debugging a code, and I think that the problem is not ours…
See the attached example: 1 create 1 DM and 2 SNES.
If I assign the same DM to both SNES, the function and Jacobean of the second are ignored, and the first one is used.
Replace the block l 138 - l. 149 with the one commented above, and the result is even weirder.
Is this the intended behavior? If so, should there be a note of this behavior in the SNESSetDM man page?
Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171101/44513269/attachment-0001.html>
Desc: twosnes.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171101/44513269/attachment-0001.obj>
