[petsc-dev] Using multiple mallocs with PETSc
Jeff Hammond
jeff.science at gmail.com
Sun Mar 12 12:19:49 CDT 2017
On Sat, Mar 11, 2017 at 9:00 AM Jed Brown <jed at jedbrown.org> wrote:
> Jeff Hammond <jeff.science at gmail.com> writes:
> > I agree 100% that multithreaded codes that fault pages from the main
> thread in a NUMA environment are doing something wrong ;-)
> > Does calloc *guarantee* pages are not mapped? If I calloc(8), do I get
> the zero page or part of the arena that's already mapped that is zeroed by
> the heap manager?
> Is your argument that calloc() should never be used in multi-threaded code?
I never use it for code that I want to behave well in a NUMA environment.
> If the allocation is larger than MMAP_THRESHOLD (128 KiB by default for
> glibc) then it calls mmap. This obviously leaves an intermediate size
> that could be poorly mapped (assuming 4 KiB pages), but it's also so
> small that it easily fits in cache.
Is this behavior standardized or merely implementation-defined? I'm not
interested in writing code that assumes Linux/glibc.
Jeff
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170312/ea408964/attachment.html>
