[petsc-dev] error configuring on KNL
Richard Tran Mills
rtmills at anl.gov
Fri Jun 30 13:44:57 CDT 2017
Hi Mark,
Take a look at the example template I've put together on Cori and see if it
is helpful to you:
/global/homes/r/rmills/proj/petsc/config/arch-cray-xc40-knl-opt.py
(I note that the optimization levels for the different compilers were
chosen after a fair amount of testing.) I'm about to check this into the
config/examples directory in the PETSc repo, so I'll appreciate any
comments you might have on this.
Also, I note that I looked at your configure options, and it looks like you
are mixing Intel compiler options (e.g., "-qopenmp-simd") with Cray
compiler options (e.g., "-hcpu=mic-knl"; you want "-xMIC-AVX512" for
Intel). Which compiler are you using? It's easy to get confused since the
same compiler wrappers are used for the Intel, Cray, and GCC compilers.
Best regards,
Richard
On Fri, Jun 30, 2017 at 6:44 AM, Mark Adams <mfadams at lbl.gov> wrote:
> Argh, thanks, that is the/a problem.
> On Fri, Jun 30, 2017 at 2:16 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> https://www.nersc.gov/users/computational-systems/cori/runni
>> ng-jobs/running-jobs-on-cori-faq/
>> Perhaps you need to specify the knl partition to srun?
>> Satish
>> On Fri, 30 Jun 2017, Mark Adams wrote:
>> > I am getting this error when I configure on KNL in with-batch. It is
>> not
>> > clear to me what compile line is being used in here. I've sent a bug
>> report
>> > to NERSC. Any ideas?
>> > Thanks,
>> > 05:13 nid00444 master= ~/petsc$ srun -n 1 ./conftest-arch-cori-knl-opt-c
>> c
>> > Please verify that both the operating system and the processor support
>> > Intel(R) AVX512F, ADX, RDSEED, AVX512ER, AVX512PF and AVX512CD
>> instructions.
>> > srun: error: nid00444: task 0: Exited with exit code 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170630/ac97d0a5/attachment.html>
