[petsc-dev] snes/ex56 target is gone
    Jed Brown
    jed at jedbrown.org
    Wed Jun 28 14:35:50 CDT 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
>    Jed,
>     Aside from its name and location this is a very useful thing. Should it be in $PETSC_DIR/lib/petsc/conf/ ? since it cannot stay in $PETSC_DIR for --prefix installs?
I guess that's a reasonable location.  The file isn't platform-dependent
so it could go elsewhere.  In that location, it should acquire a line
specifying PETSC_ARCH upon install.  The only issue with the path is
that you're actually typing it on the command line, and that would be
a starter Makefile for anyone building a larger project.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170628/f7264607/attachment.sig>
