[petsc-dev] parallel direct solvers for MG
Patrick Sanan patrick.sanan at gmail.com
Tue Jun 27 07:48:48 CDT 2017
There are some things to think about here:
 - Telescope can have some overheads wrt to duplicating operators, which
maybe you don't want for GAMG
 - The current way we use it with MG is to have a separate PCMG for each
communicator (e.g. for a 5-level method with one agglomeration step, 3
levels of GMG on 128 ranks, telescope on the coarse grid, 3 levels of GMG
on 8 ranks). I'm not sure if this is also what you'd want for GAMG.
- Logging is problematic when working with subcommunicators
On a related note, a feature which came up in a session today at PASC17
leads to a proposal which might be helpful is an additional mode for
PetscSubcomm (which is used by Telescope). This would accept a size K
(usually corresponding to a node or rack or some other topological unit of
a cluster) and do "blockwise interlaced" agglomeration, splitting the
communicator into chunks of size K and choosing an equally-space subset of
these chunks to be in the sub-communicator.
On Tue, Jun 27, 2017 at 2:35 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Jun 27, 2017 at 6:36 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> In talking with Garth, this will not work.
>> I/we am now thinking that we should replace the MG object with Telescope.
>> Telescope seems to be designed to be a superset of MG. Telescope does the
>> processor reduction, and GAMG does as well, so we would have to reconcile
>> this.  Does this sound like a good idea? Am I missing anything important?
> I don't think "replace" is the right word. Telescope only does process
> reduction. It does not do control flow for solvers,
> or restriction/prolongation. You can see telescope interacting with MG here
>   https://arxiv.org/abs/1604.07163
> I think more of this should be "default", in that the options are turned
> on if you are running GMG on a large number of procs.
> I also think GAMG should reuse the telescope code for doing reduction, but
> I am not sure how hard this is. Mark?
>   Thanks,
>     Matt
>> Mark
>> On Tue, Jun 27, 2017 at 4:48 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> Parallel coarse grid solvers are a bit broken at large scale where you
>>> don't want to use all processors on the coarse grid. The ideal thing might
>>> be to create a sub communicator, but it's not clear how to integrate this
>>> in (eg, check if the sub communicator exists before calling the coarse grid
>>> solver and convert if necessary). A bit messy. It would be nice if a
>>> parallel direct solver would not redistribute the matrix, but then it would
>>> be asking too much for it to reorder also, so we could have a crappy
>>> ordering. So maybe the first option would be best long term.
>>> I see we have MUMPS and PaStiX. Do either of these not redistribute if
>>> asked?
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170627/84c7f2ce/attachment.html>
