[petsc-dev] tonights builds on next-tmp
    Satish Balay
    balay at mcs.anl.gov
    Sun Jun 25 16:37:45 CDT 2017
The branches from last night next-tmp are now mered into master.
The following branches will be tested tonight via next-tmp
  origin/balay/fix-c89-func-test/maint
  origin/Fande-Kong/feature_snes_has_dm
  origin/hongzh/adjoint-parallel
  origin/hongzh/fix-ts-ex5adj
  origin/jed/dmda-mat-setfromoptions
  origin/jed/fix-dmda-ex51
Satish
On Sun, 25 Jun 2017, Satish Balay wrote:
> Tonight's build is again on next-tmp with same list of branches below.
> Satish
> On Sat, 24 Jun 2017, Satish Balay wrote:
> > PETSc integrators,
> > I've switched tonights builds to next-tmp with the following branches
> >   origin/barry/add-intro-help
> >   origin/barry/consistent-formating-ascii-solver-viewers
> >   origin/barry/errorcheck-fortran-petscobjectviewfromoptions
> >   origin/barry/feature-matdenseplacearray
> >   origin/barry/feature-matfdcoloringgetperturbedcolumns-f90
> >   origin/barry/feature-ts-monitor-solution
> >   origin/barry/fix/even-huger-flaw-in-ts
> >   origin/barry/fix-huge-flaw-in-ts
> >   origin/barry/fix-pcmgsetcyclesonlevel
> >   origin/barry/fix-petscobjectcopyfortranfunctionpointers
> >   origin/barry/fix-use-objectid-not-object-for-comparison-in-ts
> >   origin/barry/improve-pcasm-islocal
> >   origin/barry/update-petscfileretrieve
> >   origin/stefano_zampini/enhancements-fetidp-saddlepoint
> >   origin/stefano_zampini/feature-allow-bddc-monolithic
> > i.e other branches will not be tested tonight [so avoid merges of
> > remaining branches master]
> > Thanks,
> > Satish
