[petsc-dev] [petsc-users] How to compute RARt with A and R as distributed (MPI) matrices ?
Jed Brown
jed at jedbrown.org
Wed Jun 21 22:26:57 CDT 2017
Hong <hzhang at mcs.anl.gov> writes:
> Jed :
>> Is it better this way or as a fallback when !A->ops->rart? MatPtAP
>> handles other combinations like MAIJ.
> Do you mean
> if ( !A->ops->rart) {
> Mat Rt;
> ierr = MatTranspose(R,MAT_INITIAL_MATRIX,&Rt);CHKERRQ(ierr);
> ierr = MatMatMatMult(R,A,Rt,scall,fill,C);CHKERRQ(ierr);
> ierr = MatDestroy(&Rt);CHKERRQ(ierr);
> This does NOT work for most matrix formats because we do not have fallbacks
> for MatTranspose() and MatMatMult().
That's fine; they'll trigger an error and we'll be able to see from the
stack that it can be made to work by either implementing the appropriate
MatRARt or MatTranspose and MatMatMatMult.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170621/28d04bff/attachment.sig>
