[petsc-dev] How to compute RARt with A and R as distributed (MPI)	matrices ?
    Franck Houssen
    franck.houssen at inria.fr
    Wed Jun 21 08:00:33 CDT 2017
This works with sequential matrices.
The doc say "currently only implemented for pairs of AIJ matrices and classes which inherit from AIJ": I supposed that MPIAIJ was someway inheriting from AIJ, seems that it doesn't.
Is this kind of matrix product possible with distributed matrices in PETSc ? Or is this a known limitation ?
Do I go the wrong way to do that (= should use another method) ? If yes, what is the correct one ?
Franck
PS: running debian/testing + gcc-6.3 + bitbucket petsc.
>> mpirun -n 2 matRARt.exe seq
Mat Object: 1 MPI processes
type: seqaij
row 0: (0, 1.) (1, 0.)
row 1: (0, 0.) (1, 1.)
>> mpirun -n 2 matRARt.exe mpi
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: No support for this operation for this object type
[0]PETSC ERROR: Matrix of type <mpiaij> does not support RARt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170621/7b98268d/attachment.html>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170621/7b98268d/attachment.bin>
