[petsc-dev] Regression in PetIGA with petsc/master
    Hong
    hzhang at mcs.anl.gov
    Tue Jun 20 12:18:53 CDT 2017
Lisandro :
I fixed bug in branch hzhang/fix-ao2petscis:
https://bitbucket.org/petsc/petsc/commits/260dbea8cadd3eeca7e59945a235ff92ceae1333
I tested "-iga_dof 3" as well.
Let me know if you still encounter problems, or have any comments on this
fix.
Hong
On 20 June 2017 at 01:46, Hong <hzhang at mcs.anl.gov> wrote:
> > Thanks for detailed instruction. I built PetIGA and reproduced error.
> > Did you permute IS used as input for MatCreateSubMatrix? ISGetMinMax()
> gives
> > incorrect output min and max, thus delegates to incorrect private
> > implementation routine.
> I don't think so, but look at the implementations:
> https://github.com/dalcinl/PetIGA/blob/master/src/petigamat.c#L34
> The test fails for the case of bs=1 (default unless you pass let say
> "-iga_dof 3" for bs=3 in the command line), so...
> Maybe OApplicationToPetscIS() is not handling appropriately stride index
> sets?
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 0109
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170620/710f3970/attachment.html>
