[petsc-dev] make -f gmakefile test needs a proper help message of some sort
Jed Brown
jed at jedbrown.org
Sat Jun 17 19:19:29 CDT 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
> Thanks, sadly it is not helpful.
I wasn't saying it worked now, but that it was the target that should be
used to print help.
> $ make -f gmakefile help
> make: *** No rule to make target `help'. Stop.
>>> make -f gmakefile test XXXX
>>> appears to be a very powerful tool, as such it needs a useful help message since it is next to impossible to know where to look to find all its options.
>>> make -f gmakefile test help=1
>> This is more-or-less a convention:
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170617/a8c863ce/attachment.sig>
