[petsc-dev] MatMatMult
    Hong
    hzhang at mcs.anl.gov
    Mon Jun 12 10:02:36 CDT 2017
Pierre :
I'm not aware the "dummy function" MatMatMultNumeric_MPIDense().
Good to know you find a solution.
Hong
> Barry,
> There is no such error when you do:
> --- a/src/mat/examples/tests/ex109.c
> +++ b/src/mat/examples/tests/ex109.c
> @@ -57,7 +57,8 @@ int main(int argc,char **argv)
>    ierr = MatAssemblyEnd(B,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>    /* Test C = A*B (aij*dense) */
> -  ierr = MatMatMult(A,B,MAT_INITIAL_MATRIX,fill,&C);CHKERRQ(ierr);
> +  // ierr = MatMatMult(A,B,MAT_INITIAL_MATRIX,fill,&C);CHKERRQ(ierr);
> +  MatCreateDense(PETSC_COMM_WORLD,an,PETSC_DECIDE,PETSC_
> DECIDE,M,NULL,&C);
> What you are showing is maybe an error in the “MatDuplicate” that
> duplicates the ops->matmultnumeric, but not the workB container?
> Hong,
> Once again, I’ve been using MatMatMult without any calls to
> MatMatMultSymbolic_MPIBAIJ_MPIDense for many months.
> What you are saying is only partially true, the workspace array workB may
> be allocated in MatMatMultSymbolic_MPIBAIJ_MPIDense, but also in the
> routine MatMatMultNumeric_MPIDense which exact role, as written in the
> source code, is to bypass MatMatMultSymbolic_MPIBAIJ_MPIDense:
>     This is a "dummy function" that handles the case where matrix C was
> created as a dense matrix
>   directly by the user and passed to MatMatMult() with the
> MAT_REUSE_MATRIX option
>   It is the same as MatMatMultSymbolic_MPIAIJ_MPIDense() except does not
> create C
> Anyway, I realised that my question was dumb in the first place. In
> MatMatMultNumeric_MPIDense, I just check now when A is MATMPIBAIJ or
> MATMPIAIJ and I either cast A to Mat_MPIBAIJ* or Mat_MPIAIJ* and set
> C->ops->matmultnumeric accordingly.
> Now, everything works just fine, with *no* prior call to MatMatMult with
> MAT_INITIAL_MATRIX.
> Thanks for your patience,
> Pierre
> > On 8 Jun 2017, at 5:14 AM, Zhang, Hong <hzhang at mcs.anl.gov> wrote:
> > Pierre:
> > You must call MatMatMultSymbolic_MPIBAIJ_MPIDense() to create a dense
> matrix C (=A*B) and an internal submatrix 'workB'.
> > 'workB' will be used (and reused) to store off processor rows of B
> needed for local product of C.
> > See MatMatMultSymbolic_MPIAIJ_MPIDense().
> > Without this local storage, numeric product fails as shown from your
> test.
> > Again, for using parallel MatMatMult(), you must use
> MatMatMultSymbolic() to create C, then reuse it.
> > Hong
> > ________________________________________
> > From: Barry Smith [bsmith at mcs.anl.gov]
> > Sent: Wednesday, June 07, 2017 9:31 PM
> > To: Pierre Jolivet
> > Cc: Zhang, Hong; For users of the development version of PETSc
> > Subject: Re: [petsc-dev] MatMatMult
> >> On Jun 7, 2017, at 1:29 AM, Pierre Jolivet <pierre.jolivet at enseeiht.fr>
> wrote:
> >>> On 6 Jun 2017, at 11:21 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>>> On Jun 6, 2017, at 1:52 PM, Pierre Jolivet <
> Pierre.Jolivet at enseeiht.fr> wrote:
> >>>> On Tue, 6 Jun 2017 13:44:06 -0500, Hong wrote:
> >>>>> Pierre :
> >>>>>> Yes, of course I defined (*C)->ops->matmultnumeric =
> >>>>>> MatMatMultNumeric_MPIBAIJ_MPIDense in
> >>>>>> MatMatMultSymbolic_MPIBAIJ_MPIDense.
> >>>>>> However, the routine MatMatMultSymbolic_MPIBAIJ_MPIDense is never
> >>>>>> reached when calling MatMatMult with scall == MAT_REUSE_MATRIX
> >>>>> (http://www.mcs.anl.gov/petsc/petsc-current/src/mat/
> interface/matrix.c.html#line9487
> >>>>>> [1], just to be sure I added a dummy printf in
> >>>>>> MatMatMultSymbolic_MPIBAIJ_MPIDense and nothing is displayed with
> >>>>>> MAT_REUSE_MATRIX, MAT_INITIAL_MATRIX works as intended)
> >>>>> MatMatMultSymbolic_xxx() is called only for MAT_INITIAL_MATRIX,
> >>>>> during which, it defines
> >>>>> (*C)->ops->matmultnumeric = MatMatMultNumeric_MPIBAIJ_MPIDense;
> >>>> Sorry, I was not thorough enough. What I meant to say is that I never
> call MatMatMult with MAT_INITIAL_MATRIX, so MatMatMultSymbolic_xxx is never
> called.
> >>>  It is not designed to work that way. The reuse is specifically to
> reuse a matrix obtained with a call to initial_matrix, not to reuse a
> random matrix the user provides. The reason is that the symbolic stage
> may/does build additional data structures that are used for the multiples
> that the user cannot see or build directly.
> >> I’m doing:
> >>  MatCreateDense(PETSC_COMM_WORLD, m, n, M, N, in, &B);
> >>  MatCreateDense(PETSC_COMM_WORLD, m, n, M, N, out, &C);
> >>  MatMatMult(A, B, MAT_REUSE_MATRIX, PETSC_DEFAULT, &C);
> >> This works perfectly fine with A of type MPIAIJ, but once again,
> everything is hardwired for this only type.
> >   Hmm, I modified src/mat/examples/tests/ex109.c to create the dense D
> matrix with a MatDuplicate() instead of INITIAL MATRIX and when I run in
> parallel I get
> > $ petscmpiexec -n 2 ./ex109
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Petsc has generated inconsistent data
> > [0]PETSC ERROR: Container does not exist
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.7.6, unknown
> > [0]PETSC ERROR: ./ex109 on a arch-basic named Barrys-MacBook-Pro.local
> by barrysmith Wed Jun  7 21:24:59 2017
> > [0]PETSC ERROR: Configure options PETSC_ARCH=arch-basic
> > [0]PETSC ERROR: #1 MatMPIDenseScatter() line 487 in
> /Users/barrysmith/Src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c
> > [0]PETSC ERROR: #2 MatMatMultNumeric_MPIAIJ_MPIDense() line 557 in
> > [0]PETSC ERROR: #3 MatMatMult() line 9492 in /Users/barrysmith/Src/petsc/
> src/mat/interface/matrix.c
> > [0]PETSC ERROR: #4 main() line 79 in /Users/barrysmith/Src/petsc/
> > [0]PETSC ERROR: PETSc Option Table entries:
> > [0]PETSC ERROR: -malloc_test
> > it does run sequentially.
> >> According to your answer, Barry, I think the manual should be adjusted
> accordingly because to me what I’m trying to achieve should be possible as
> is (the fact that it is possible with MPIAIJ is also puzzling):
> >> "In the special case where matrix B (and hence C) are dense you can
> create the correctly sized matrix C yourself and then call this routine
> with MAT_REUSE_MATRIX, rather than first having MatMatMult() create it for
> you. […]” (http://www.mcs.anl.gov/petsc/petsc-current/docs/
> manualpages/Mat/MatMatMult.html)
> >   Yes, you are right this documentation is wrong. This is only true for
> sequential dense matrices. I've fixed the manual page in master.
> >  Barry
> >>>> Is there another way?
> >>>> I cannot use MAT_INITIAL_MATRIX because I want to manage the
> underlying memory, and I'm guessing MAT_INITIAL_MATRIX will delete whatever
> is in C and reallocate memory on its own.
> >>> The memory in C is just a dense array so presumably you want to use
> some "application" memory for this space?
> >>>  The simplest way for you to achieve this is to call the
> MatMatMultSymbolic() then dig out the underly array of the matrix, call
> PetscFree() on it and put in your own array. Yes, this is slightly hacky,
> but it will work fine within the current PETSc model.
> >> Yeah, alright, I already need to tinker with the MatDensePlaceArray/MatDenseResetArray
> so I can figure something out as well for this.
> >> Thanks,
> >> Pierre
> >>> Barry
> >>>> Thanks in advance for your help,
> >>>> Pierre
> >>>>> Then MatMatMult(A,C,MAT_REUSE_MATRIX,..) calls
> >>>>> (*(*C)->ops->matmultnumeric)(A,B,*C); (line 9432 in matrix.c)
> >>>>> which should go to MatMatMultNumeric_MPIBAIJ_MPIDense.
> >>>>> You may follow a debugging process
> >>>>> using petsc/src/mat/examples/tests/ex109.c
> >>>>> Are you working on a branch of petsc? If so, I may take a look and
> >>>>> see what is the problem.
> >>>>> Hong
> >>>>>>>> 2) I'm having trouble when scall == MAT_REUSE_MATRIX. Here,
> >>>>> http://www.mcs.anl.gov/petsc/petsc-current/src/mat/impls/
> dense/mpi/mpidense.c.html#line1208
> >>>>>>> [2]
> >>>>>>>> [2] it looks that the numeric part of the MatMatMult (which is
> >>>>>>>> called when scall == MAT_REUSE_MATRIX) is hardwired to this
> >>>>>>>> routine
> aij/mpi/mpimatmatmult.c.html#line376
> >>>>>>> [3]
> >>>>>>> [3].
> >>>>>>> br>
> >>>>> s.anl.gov/petsc/petsc-current/src/mat/impls/aij/mpi/
> mpimatmatmult.c.html#line556"
> >>>>>>> rel="noreferrer"
> >>>>> target="_blank">http://www.mcs.anl.gov/petsc/petsc-
> current/src/mat/impls/aij/mpi/mpimatmatmult.c.html#line556
> >>>>>>> [2]
> >>>>>>> [4]
> >>>>>>> [3]
> >>>>>>> [5]
> >>>>> Links:
> >>>>> [1]
> >>>>> [2]
> >>>>> [3]
> >>>>> [4]
> >>>>> [5]
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170612/d2f7f5eb/attachment.html>
