[petsc-dev] MatMatMult
    Hong
    hzhang at mcs.anl.gov
    Tue Jun  6 13:58:04 CDT 2017
What is your calling procedure for using MatMatMultNumeric_MPIBAIJ_MPIDense?
Hong
On Tue, Jun 6, 2017 at 1:52 PM, Pierre Jolivet <Pierre.Jolivet at enseeiht.fr>
wrote:
> On Tue, 6 Jun 2017 13:44:06 -0500, Hong wrote:
>> Pierre :
>> Yes, of course I defined (*C)->ops->matmultnumeric =
>>> MatMatMultNumeric_MPIBAIJ_MPIDense in
>>> MatMatMultSymbolic_MPIBAIJ_MPIDense.
>>> However, the routine MatMatMultSymbolic_MPIBAIJ_MPIDense is never
>>> reached when calling MatMatMult with scall == MAT_REUSE_MATRIX
>> (http://www.mcs.anl.gov/petsc/petsc-current/src/mat/interfac
>> e/matrix.c.html#line9487
>>> [1], just to be sure I added a dummy printf in
>>> MatMatMultSymbolic_MPIBAIJ_MPIDense and nothing is displayed with
>>> MAT_REUSE_MATRIX, MAT_INITIAL_MATRIX works as intended)
>>  MatMatMultSymbolic_xxx() is called only for MAT_INITIAL_MATRIX,
>> during which, it defines
>> (*C)->ops->matmultnumeric = MatMatMultNumeric_MPIBAIJ_MPIDense;
> Sorry, I was not thorough enough. What I meant to say is that I never call
> MatMatMult with MAT_INITIAL_MATRIX, so MatMatMultSymbolic_xxx is never
> called.
> Is there another way?
> I cannot use MAT_INITIAL_MATRIX because I want to manage the underlying
> memory, and I'm guessing MAT_INITIAL_MATRIX will delete whatever is in C
> and reallocate memory on its own.
> Thanks in advance for your help,
> Pierre
> Then MatMatMult(A,C,MAT_REUSE_MATRIX,..) calls
>>  (*(*C)->ops->matmultnumeric)(A,B,*C); (line 9432 in matrix.c)
>> which should go to MatMatMultNumeric_MPIBAIJ_MPIDense.
>> You may follow a debugging process
>> using petsc/src/mat/examples/tests/ex109.c
>> Are you working on a branch of petsc? If so, I may take a look and
>> see what is the problem.
>> Hong
>> 2) I'm having trouble when scall == MAT_REUSE_MATRIX. Here,
>> http://www.mcs.anl.gov/petsc/petsc-current/src/mat/impls/den
>> se/mpi/mpidense.c.html#line1208
>>> [2]
>>>> [2] it looks that the numeric part of the MatMatMult (which is
>>>>> called when scall == MAT_REUSE_MATRIX) is hardwired to this
>>>>> routine
>> http://www.mcs.anl.gov/petsc/petsc-current/src/mat/impls/aij
>> /mpi/mpimatmatmult.c.html#line376
>>> [3]
>>>> [3].
>>>> br>
>> s.anl.gov/petsc/petsc-current/src/mat/impls/aij/mpi/mpimatma
>> tmult.c.html#line556"
>>> rel="noreferrer"
>> target="_blank">http://www.mcs.anl.gov/petsc/petsc-current/
>> src/mat/impls/aij/mpi/mpimatmatmult.c.html#line556
>>> [2]
>>> [4]
>>>> [3]
>>> [5]
>> Links:
>> [1]
>> http://www.mcs.anl.gov/petsc/petsc-current/src/mat/interface
>> [2]
>> [3]
>> [4]
>> [5]
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170606/ed000082/attachment.html>
