[petsc-dev] I think TS should have a TSSetMassMatrix()
Stefano Zampini
stefano.zampini at gmail.com
Mon Jul 24 05:03:47 CDT 2017
2017-07-24 11:26 GMT+03:00 Lisandro Dalcin <dalcinl at gmail.com>:
> On 23 July 2017 at 21:42, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Then explicit methods could automatically use a solve to apply the
> mass matrix inverse for each "right hand side" application and implicit
> methods could automatically "drop in" the mass matrix with the shift when a
> right hand side Jacobian is given also. Instead of requiring the user to
> handle this themselves. Are there any gotcha's that I am missing or is this
> relatively straightforward?
IMHO I think that it is not worth the complication. I value the generality
of the current API, that already is somewhat cumbersome to maintain.
Users providing the RHS function + mass matrix already know that they
should do M^-1 * rhsvec to compute the rhs function.
Same for the RHS jacobian.
> > Why wouldn't we have this interface?
What if the user provides MassMatrix + IFunction/IJacobian +
RHSFunction/RHSJacobian? Are you going to handle all the possible
scenarios? Error? dump a warning with PetscInfo? Users that will need such
a new API usually don't read PetscInfo output
> As usual, the problem is on defining the interface and the trade on
> performance and generality. But I'm definitely +1 on this.
> > Almost for sure MFEM must have this type of API.
No. AFAIK, sundials has it, not MFEM.
Natively in MFEM, they just suppors explicit or SDIRK. They also have
interface to TS and Sundials.
See https://github.com/mfem/mfem/blob/master/examples/ex9.cpp#L329 for
native explicit ode solvers in MFEM.
See here for the virtual method that allows using SDIRK
https://github.com/mfem/mfem/blob/master/examples/ex10.cpp#L91
Here for sundials https://github.com/mfem/mfem/tree/master/examples/sundials
With that said, if you want to use TS through MFEM, here you have an
example https://github.com/mfem/mfem/blob/master/examples/petsc/ex9p.cpp,
which is meant to be illustrative of the capabilities of the
IFunction/RHSFunction (and jacobians) API in PETSc, not efficiency.
> Stefano will love it for sure...
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 0109
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170724/68b36ae9/attachment.html>
