[petsc-dev] DMCopyDMSNES
Thu Jul 20 14:33:29 CDT 2017
   Ok, I think we should move it to the public headers unless Jed objects.
   Barry
BTW: I have hate DMSNES and friends but don't have a solution for the problem it solves so have to live with it.
> On Jul 20, 2017, at 1:40 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> It is used in SLEPc in code contributed by Fande Kong.
> https://bitbucket.org/slepc/slepc/pull-requests/14/example-34-work-with-the-monolithic-update/diff
> I have no problem in including the private header, but we in SLEPc always try to use public headers only.
> Jose
>> El 20 jul 2017, a las 20:21, Barry Smith <bsmith at mcs.anl.gov> escribió:
>> It is developer level, so might not belong in the public headers.
>> Do you need it in the public headers?
>>> On Jul 20, 2017, at 11:27 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>>> DMCopyDMSNES() is documented
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/DMCopyDMSNES.html
>>> but it is defined in the private header snesimpl.h. Shouldn't it be in the public header petscsnes.h?
>>> Jose
