[petsc-dev] What should MatDuplicate_SeqAIJMKL() do?
Richard Tran Mills rtmills at anl.gov
Wed Jul 19 10:55:35 CDT 2017
Fellow PETSc developers,
I'm trying to figure out what my MatDuplicate() implementation for AIJMKL
should do when the sparse inspector-executor model is being used. I think
that the behavior should be
* If MAT_COPY_VALUES has been specified, then mkl_sparse_optimize() should
be executed for the new matrix inside MatDuplicate_SeqAIJMKL().
* If MAT_COPY_VALUES has not been specified, then don't do the
mkl_sparse_optimize(), as the user is going to have to specify the nonzero
entries at some point, and then do MatAssemblyBegin/End (which calls
mkl_sparse_optimize).
I'm a little unclear on all of the situations in which MatDuplicate gets
used, however, so let me know if I'm misunderstanding something.
Richard
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170719/e6c565c2/attachment.html>
