[petsc-dev] 3rd party GPU AMG solvers
Karl Rupp
rupp at iue.tuwien.ac.at
Fri Jul 14 09:22:49 CDT 2017
> it will nonetheless require a lot of convincing that at best they
> get moderate speed-ups, not the 580+x claimed in some of those early
> GPU papers...
> Karli, we are talking about two different things. You are talking about
> performance, and I applaud you for that, but I am talking about giving
> customers what they want. They want to investigate GPUs. I will say that
> I do not anticipate seeing any performance improvement.
it is fine to say that "here is what you can try, but don't expect
performance gains". My experience is, however, that people then go
ahead, try it, *and* expect performance gains (of course for
inappropriate system sizes, etc.). Since they invested time in exploring
GPUs, there is an implicit expectation that there must be a ROI...
Best regards,
Karli
> The fusion folks that I work with, and I assume other DOE
> offices, are just looking at their codes, subroutine by
> subroutine, and having postdocs look at GPUising them. We just
> need intelligent answers to their questions. Even if we as
> sentient and passionate human being have opinions on the
> approach that is implied by their questions, it is part of my
> job to just give them a professional answer.
> In the past ~18 months I've worked with applications that wanted to
> use GPUs in just that manner. Needless to say that you end up with
> touching almost everything to actually beat an existing (efficient)
> CPU-based application by less than a factor of 2. This involves
> MPI-parallel applications; it's much easier to get higher speedups
> if you don't need to communicate across ranks.
> I have enough now (thanks Jed and Lorena, et al!) to answer the
> AMGx question sufficiently, and if you could give me a quick
> assessment of where we are with hypre's GPU solver that would be
> great.
> does "work in progress" suffice? ;-)
> I will advertise it "as is" (this is a term of art in US law).
> Thanks again,
> Best regards,
> Karli
> On Thu, Jul 13, 2017 at 11:16 PM, Karl Rupp
> <rupp at iue.tuwien.ac.at <mailto:rupp at iue.tuwien.ac.at>
> <mailto:rupp at iue.tuwien.ac.at <mailto:rupp at iue.tuwien.ac.at>>>
> wrote:
> Hi Mark,
> I hear Hypre has support for GPUs in a May release. Any
> word on
> the status of using it in PETSc?
> as far as I know, it is currently not supported in PETSc.
> I'll have
> a look at it and see what needs to be done to enable it.
> And we discussed interfacing to AMGx, which is complicated
> (precluded?) by not releasing source. Anything on the
> potential
> of interfacing to AMGx? I think it would be great to
> make this
> available. It is on a lot of checkboxes. I would love
> to be able
> to say, yea you can use it.
> Lorena Barba's group actually interfaced PETSc to AMGx at
> some point
> (presented at GTC 2016 if I'm not mistaken). I'll reach out
> to them,
> maybe they have something to contribute.
> Best regards,
> Karli
