[petsc-dev] Fwd: no petsc on Edison
    Mark Adams
    mfadams at lbl.gov
    Thu Jan 26 13:18:07 CST 2017
On Thu, Jan 26, 2017 at 10:53 AM, Hong <hzhang at mcs.anl.gov> wrote:
> Mark:
> I see MatTransposeMatMult() is called by PCGAMGCoarsen_AGG().
Oh, right. I was thinking of RAP.
> When Gmat1 is created, if you know it is symmetric, then set
> Gmat1->symmetric = PETSC_TRUE;
> I can add following:
> +    if (Gmat1->symmetric) {
> +      ierr = MatMatMult(Gmat1, Gmat1, MAT_INITIAL_MATRIX, PETSC_DEFAULT,
> &Gmat2);CHKERRQ(ierr);
> +    } else {
> +      ierr = MatTransposeMatMult(Gmat1, Gmat1, MAT_INITIAL_MATRIX,
> PETSC_DEFAULT, &Gmat2);CHKERRQ(ierr);
That would be great thanks. When you do that I can change ex56 to use this,
test it, and update the test.
> In this way, MatTransposeMatMult() can be replace with MatMatMult() when
> Gmat1 is symmetric.
> Hong
>>>  MatTransposeMatMult() tends to use much larger ctable than MatMatMult.
>>> Is your matrix symmetric? If so, MatMatMult() will use smaller ctable
>>> and require less communication.
>> Humm, that is good to know.
>> How would I add this to GAMG? Does the user tag the matrix as symmetric
>> and then GAMG checks this, explicitly computes a transpose of P, calls
>> MatMatMult twice?
>> Thanks,
>> Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170126/b885dcef/attachment.html>
