[petsc-dev] Introducing new "test harness" to PETSc
Tobin Isaac
tisaac at uchicago.edu
Tue Jan 24 00:23:38 CST 2017
How does tab completion work? I've tried `make -f gmakefile sys<Tab>` in zsh and bash but got nothing.
Thanks to everyone who worked on this, I just have two other questions/requests:
- What’s the best way to update the test definitions after fiddling with /*TEST*/ blocks? It would be nice if gmakegentests.py would run automatically when sources are newer than their tests.
- Is there a technical reason suffixes can only be specified at the top level? It would help with concision if subtest suffixes could append to their parent suffixes.
Cheers,
Toby
Sent: Tuesday, 17 January, 2017 20:55
To: Matthew Knepley<mailto:knepley at gmail.com>, Barry Smith<mailto:bsmith at mcs.anl.gov>
Cc: petsc-dev<mailto:petsc-dev at mcs.anl.gov>
Matthew Knepley <knepley at gmail.com> writes:
> Gripes:
> 1) How do I run an individual test run?
make -f gmakefile sys_tutorials-runex5
(tab completion works) or use a search that matches only that run.
> I use
> make -f gmakefile test searchin=plex
> to run plex tests, and I think
> make -f gmakefile test searchin=plex*ex1
Due to make syntax, % is the internal string matcher.
> will work. However, how do I select ex1_2?
make -f gmakefile test search=plex%ex1_2
> 2) How do I replace the output which exists with the output of the
> current test run?
> This is amazingly useful after changes.
I have this script ~/bin/diffupdate:
#!/bin/sh
args=
if [ "$1" = "-u" ]; then
args="-u"
shift
fi
new="$2"
ref="$1"
diff $args "$ref" "$new"
ret=$?
echo "Updating $new --> $ref"
mv "$new" "$ref"
exit $ret
Then I run
make -f gmakefile test search=plex% DIFF=diffupdate
It prints the diff and replaces the reference file (first argument) with
the second.
> 3) How do I give extra arguments with the make interface, rather than
> test_harness?
That is, run some modification of the test and still do the diff, but
don't change the reference output? I have used PETSC_OPTIONS for that.
make .... PETSC_OPTIONS=-more_magic
> Once I have all the functionality of my Python stuff, I will throw it away.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170124/3f8b994f/attachment.html>
