[petsc-dev] Fwd: [Bitbucket] Pipeline for master failed on	c3c607c (petsc/petsc)
    Sean Farley
    sean at farley.io
    Mon Jan 23 18:17:33 CST 2017
Sean Farley <sean at farley.io> writes:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>    Once something bugs you with irrelevant things you pretty soon start to ignore it and then it becomes useless.
> That's a fair point. I've pinged the pipelines team but they are in
> Sydney, so it'll be a long round-trip.
I talked with the team about this and they agreed it could be improved
(in this case, they think the disk ran out of space):
https://bitbucket.org/site/master/issues/13763/more-precise-error-message
Since I'm the reporter, I'll get notified when the ticket changes.
Hopefully, I won't forget this exists :-)
